Disk Space Discovery suddenly stopped working correctly
  • paulrgod
    • May 2023
    Hi Guys,
    I'm after a little help around Disk Space Monitoring on our Zabbix. To my knowledge nothing should have changed.
    I have the item prototype set up as follows :-
    Name - Free disk space on $1
    Type - Zabbix agent
    Key - vfs.fs.size[{#FSNAME},free]
    This has worked fine for a long time, sending alerts out to our Ticketing system with the correct subject including the correct drive letter (eg 'Free disk space on C:').
    Recently this has stopped working and each alert received now just shows the subject as 'Free disk space on $1' as per the name.
    Any suggestions on what may be happening and how to fix this?
    Thanks in advance.
    Paul
    • 4996
    Here you are wrong... you have definitely upgraded a version. Support for positional macros like $1 has been dropped... It was deprecated already for many versions (since 4) and has now been dropped..
    Replace your trigger name with "Free disk space on {#FSNAME}" and let discovery run again...
