correct templete for Cisco Nexus 7004
  • sbdcunha
    • May 2023
    • 27
    Dears ,
    I have zabbix 6.4 Running with no issues
    Just wanted to know the correct templete for monitoring Cisco Nexus 7004 switch
    There is for cisco nexus 9000 avaliable
    I am presently using Cisco snmp
    But i see that Cpu , Fan and temperature are not monitored
    Any advice and help for the right templete will be much appreciated
    Thanks and Regards
    Simon
  • sbdcunha
    • May 2023
    • 27
    Dear All,
    can I use the Cisco Nexus 9000 built in template to monitor my Nexus 7004 Switch
    Apprecite your advice
    Thanks and regards
    simon
