I've deployed 2 separate Vcenter7 Zabbix templates. Both behaving strange with latest data.
I only modified the host groups organization under discovery so I have:
Company/VMWARE
Company/VMWARE/HOSTS
Company/VMWARE/VC
Company/VMWARE/VMs
I don't understand this display issue / filtering on latest data.
If I select Host Groups = Company/VMWARE/VMs (Where all discovered VMs go)
Not every VM is listed that has been discovered.
But if I choose both Host groups Company/VMWARE/VMs + manually select the host then all discovered VMs are displayed to choose from.
If I select a VM that is "hidden" when viewing the host group alone it has all the same data present.
Then if I select both host group Company/VMWARE/VMs + select every VM under hosts it will also not display them all. Just like if I filtered by host group alone.
(No sub filter tags selected)
Can someone please share why is happening? Thank you.
Edit: Further review the issue appears to be related by two factors.
If Vcenter VM itself is selected it impacts some other VMs to display.
Then also an issue with like named VMs. For example TMRD.Domain.local + TMRDS.Domain.local. Only wants to display 1 at a time.
Company/VMWARE
Company/VMWARE/VC
Company/VMWARE/VMs
