Telegram Webhook
  • Koldogut
    • Jul 2023
    • 9
    Telegram Webhook
    After setting up according official documentation (https://www.zabbix.com/la/integrations/telegram) I always get same error below:
    I've checked many forums and no telegram ID nor firewall api-calling issues found, any clues? How could I debug this issue deeply? this is the most accurate info I can get when testing the Media Type:
    00:00:00.000 [Debug] [Telegram Webhook] notification failed: TypeError: cannot read property 'toLowerCase' of undefined
    I'm running Zabix Server ver. 6.4 in a docker container with PostgreSQL database hosted in other docker container.
    Thanks in advance!
  • Koldogut
    • Jul 2023
    • 9
    Please Experts, I need yor help!
      • 5004
      If you test, do you give some content to your event? like message? Seems like it is trying to "lowercase" something that is undefined...
      • Koldogut
        • Jul 2023
        • 9
        No matter what I put, it always shows same error. Is there any way to get an extended log? Log link below provides same info
          • 5004
          If you look into script in media config, then you can see lines starting with "Zabbix.log(4....". If you change that 4 to 3, you should get a bit more data into server log. (https://www.zabbix.com/documentation...ver#debuglevel) .Or increase logging level of alerter process..(https://www.zabbix.com/documentation...untime-control)
