Zabbix Not Alerting for vCenter 7 Problems - Seeking Assistance
  • sinfraefl@gmail.com
    • Sep 2023
    Hello Friends ,
    Im a new to Zabbix , I've encountered an issue with my Zabbix setup where it's not alerting me for problems in my vCenter 7 environment. I have successfully configured Zabbix to retrieve data from vCenter, but the alerting mechanism seems to be failing. I'm seeking assistance from the Zabbix community to help me resolve this problem.
    Deployment Info :
    -Zabbix from packages 6.0
    - Two Servers used Web and DB
    - Template used , VMware Hypervisor , FQDN and Guest
    -Zabbix config file edit to enable VMware Collector
    Please your help with this matter would be appreciated .
  • tim.mooney
    • Dec 2012
    • 1437
    Does the account you want to be alerted have at least "Read" permission for the host that generated the problem event?
    See the "Attention" box in the documentation: https://www.zabbix.com/documentation...ration/message
      [email protected] commented
      Does the account you want to be alerted have at least "Read" >> Yes
      Its not issue with receiving alerts , i can not see the alerts even in Zabbix Dashboard ( Problems By Severity ) while in Latest Data a lot of items exists .i See Zabbix Discovered all VMs , DataStores ,Clusters and DC and my asking why i cant see any problems in Dashboard or By Receive an email while i know there is a lot of them in my Environment .
    • 5004
    Sorry but... what exactly do you mean with "it's not alerting me for problems in my vCenter 7 environment" ?
    Is it, that it never generates any events? (may be data collection issue). Is it, that it is not creating alerts based on those events? (might be, what tim.mooney already pointed)
    Do you see actual problems in Zabbix?
      • Sep 2023
      In Zabbix I can see a lot of Data collected when navigate to Latest Data and even i saw a lot of event say cluster health red , and also in vCenter i see a lot of alarms related to Datastore . but in Zabbix Dashboard when Monitor Problems by Severity all sections Zero no at least one problem listed , and on Email i didn't receive any thing and i sure my Media Configuration is working and tested , this is my problem .
      • vijayk
        • May 2023
        • 305
        VMware template by default does not have any triggers. If you are using it with vCenter. Make sure trigger are showing in Host.
          This what i see in info of triggers ( Cannot evaluate function last(/VCENTERFQDN/vmware.hv.status[{$VMWARE.URL},{$VMWARE.HV.UUID}]): item is not supported.)
      • vijayk
        • May 2023
        • 305
        Please verify that item with this event is exist in template or not. Might be something is missing or incorrect typed.
          First thank you for your support , second i can see all items assigned to vCenter for both Templates VMware Hypervisor and VMware Guest contain error and status is unsupported . .
          Info says :
          Unknown hypervisor uuid. // For items with VMware Hypervisor Template
          Unknown virtual machine uuid. // For items with VMware guest Template
        • 5004
        https://www.zabbix.com/integrations/vmware there are some triggers present... But compared to items count, not too many..
        Here seems to be data collection issue. triggers cannot be calculated as items are not supported... That part needs investigation... Why there are unknown UUID-s...
