SelectParentDependencies - error
  • Renat_euro
    • Sep 2023
    Hi all!
    I upgraded zabbix from version 4.4.4 > 6.4.6 and everything went well.
    I have an SLA report and in version 4.4.4 it worked fine.
    My report works through requests and it accesses "selectParentDependencies": "extend" which is described in the documentation https://www.zabbix.com/documentation...ce/service/get
    When debugging, I send JSON which is what it does
        "jsonrpc": "2.0",
        "method": "service.get",
        "params": {
            "output": "extend",
            "sortfield": "sortorder"
            "selectParentDependencies": "extend",
        "auth": "90253303437e1bbb5somesomesome4405dc1b6423f6",
        "id": 1
    answer
        "jsonrpc": "2.0",
        "error": {
            "code": -32700,
            "message": "Parse error",
            "data": "Invalid JSON. An error occurred on the server while parsing the JSON text."
        "id": null
    but if I remove "selectParentDependencies": "extend",
    then I get closer to the correct answer
        "jsonrpc": "2.0",
        "params": {
            "output": "extend",
        "auth": "93250some37some someb64ee62a440523ef0ef6",
        "id": 1
        "jsonrpc": "2.0",
        "result": [
                "serviceid": "250",
                "name": "L2",
                "status": "-1",
                "algorithm": "1",
                "sortorder": "0",
                "weight": "0",
                "propagation_rule": "0",
                "propagation_value": "0",
                "description": "",
                "uuid": "7e6aa2d53f6e42b1a34b017fa403cb76",
                "created_at": "946684800",
                "readonly": true
                "serviceid": "256",
                "name": "L2",
                "status": "-1",
                "algorithm": "1",
                "sortorder": "0",
                "weight": "0",
                "description": "",
                "readonly": true
    In the SLA report, everything is fine with me
    Why doesn't selectParentDependencies work? How can this problem be solved?​ Help who faced this problem))
    • 5004
    since 6.0 .. https://www.zabbix.com/documentation...ntDependencies
    Support for it is dropped...
