Cannot connect to [0.0.0.0:10050]: [4] Interrupted system call
  • dieselfluxcapacitor
    • Jul 2023
    • 11
    Running Zabbix 6.4 on Ubuntu 20.04 LTS
    I have many Windows clients running Zabbix Agent 2 version 6.4.6 that are exhibiting two issues: their availability in the Zabbix frontend is consistently flapping, and remote commands executed against the passive agent return with the error "Cannot connect to [0.0.0.0:10050]: [4] Interrupted system call" (where 0.0.0.0 is redacted IP address).
    To troubleshoot, I've tried the following:
    • changing the update interval frequency of the Windows: Zabbix agent availability item
    • lowering the Timeout parameter on the Zabbix Server from 3 to 2 seconds
    • increasing the Timeout parameter on the Zabbix Server from 3 to 5 seconds
    • increasing the number of unreachable poller data collector instances on the Zabbix Server
    • disabling TLS/PSK encrypted communication between sever and agent
    • disabling layer 7 packet inspection in the network firewall
    • enabling verbose logging on the client and server and examining the logs for hints
    So far, nothing has lead me to any clues as to how to resolve this issue. Has anyone else run into this issue and resolved it? I see there have been others on the forums who've complained, but I don't see any resolutions posted
    1. [4] Interrupted system call - ZABBIX Forums​
    2. cannot connect to [[x.x.x.x]:10050]: [4] Interrupted system call - ZABBIX Forums
    3. performance testing - Zabbix can't get value from Agent (Interrupted system call) - Stack Overflow​
    4. Agent Failed / Interrupted System Call (4) : zabbix (reddit.com)​​
  • vijayk
    • May 2023
    • 305
    Did you check with debug logs in agent?
      • Jul 2023
      • 11
      I see that the client dropped out multiple times overnight. Let's focus on the instances at 3:00 and 5:00
Name:	2023-10-10 07_57_42-History.png
      In my client log I see that the agent just restarted around 3:00. Here's the details of the log:
      2023/10/10 03:00:06.280829 Zabbix Agent 2 stopped. (6.4.7)
      2023/10/10 03:00:39.269900 Starting Zabbix Agent 2 (6.4.7)
      2023/10/10 03:00:39.282973 OpenSSL library (OpenSSL 3.0.11 19 Sep 2023) initialized
      2023/10/10 03:00:39.282973 using configuration file: C:\Program Files\Zabbix Agent\zabbix_agent2.conf
      2023/10/10 03:00:39.288719 lowering the plugin WindowsPerfInstance capacity to 1 as the configured capacity 100 exceeds limits
      2023/10/10 03:00:39.288719 using plugin 'WindowsPerfInstance' (built-in) providing following interfaces: exporter
      2023/10/10 03:00:39.288719 using plugin 'WindowsPerfMon' (built-in) providing following interfaces: exporter, collector, runner
      2023/10/10 03:00:39.288719 using plugin 'WindowsServices' (built-in) providing following interfaces: exporter
      2023/10/10 03:00:39.288719 using plugin 'Wmi' (built-in) providing following interfaces: exporter
      2023/10/10 03:00:39.288719 using plugin 'ZabbixAsync' (built-in) providing following interfaces: exporter
      2023/10/10 03:00:39.288719 using plugin 'ZabbixStats' (built-in) providing following interfaces: exporter, configurator
      2023/10/10 03:00:39.288719 lowering the plugin ZabbixSync capacity to 1 as the configured capacity 100 exceeds limits
      2023/10/10 03:00:39.288719 using plugin 'ZabbixSync' (built-in) providing following interfaces: exporter
      2023/10/10 03:00:41.419994 Plugin communication protocol version is 6.4.0
      2023/10/10 03:00:41.420514 Zabbix Agent2 hostname: [CLC-01A-L3]
      2023/10/10 03:00:42.599065 [101] cannot connect to [0.0.0.0:10051]: dial tcp: lookup 0.0.0.0: no such host
      2023/10/10 03:00:42.599065 [101] active check configuration update from host [CLC-01A-L3] started to fail
      2023/10/10 03:00:42.599627 [101] cannot connect to [0.0.0.0:10051]: dial tcp: lookup 0.0.0.0: no such host
      2023/10/10 03:00:42.599627 [101] sending of heartbeat message for [CLC-01A-L3] started to fail
      2023/10/10 03:00:55.526590 [101] active check configuration update from [0.0.0.0:10051] is working again
      2023/10/10 03:01:43.523935 [101] sending of heartbeat message to [0.0.0.0:10051] is working again
      2023/10/10 05:21:47.682186 [101] cannot connect to [0.0.0.0:10051]: dial tcp :0->10.128.254.36:10051: i/o timeout
      2023/10/10 05:21:47.682186 [101] active check configuration update from host [CLC-01A-L3] started to fail
      2023/10/10 05:21:53.673900 [101] active check configuration update from [0.0.0.0:10051] is working again
      2023/10/10 05:32:52.677863 [101] cannot connect to [0.0.0.0:10051]: dial tcp :0->10.128.254.36:10051: i/o timeout
      2023/10/10 05:32:52.677863 [101] active check configuration update from host [CLC-01A-L3] started to fail
      2023/10/10 05:32:58.686397 [101] active check configuration update from [0.0.0.0:10051] is working again​
      This is what I see server-side for the same time period:
      2431:20231010:030019.683 Zabbix agent item "agent.hostname" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2372:20231010:030039.412 temporarily disabling Zabbix agent checks on host "CLC-01A-L3": interface unavailable
        2448:20231010:030050.173 enabling Zabbix agent checks on host "CLC-01A-L3": interface became available
        2085:20231010:030142.996 Zabbix agent item "perf_counter_en["\Memory\Page Faults/sec"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2162:20231010:030158.199 Zabbix agent item "agent.version" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2307:20231010:030214.266 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2284:20231010:030233.131 Zabbix agent item "agent.version" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2369:20231010:030308.007 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2322:20231010:030323.015 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2275:20231010:030343.279 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2459:20231010:030418.556 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2272:20231010:030433.047 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2298:20231010:030438.035 Zabbix agent item "service.info["CiscoAMP",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2309:20231010:030453.051 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2403:20231010:030453.667 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2297:20231010:030528.380 Zabbix agent item "perf_counter_en["\Memory\Cache Bytes"]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2441:20231010:030543.105 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2329:20231010:030608.483 Zabbix agent item "system.swap.size[,total]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2441:20231010:030623.038 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2173:20231010:030726.082 Zabbix agent item "perf_counter_en["\Memory\Cache Bytes"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2455:20231010:030742.399 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2103:20231010:030744.032 Zabbix agent item "wmi.getall[root\cimv2,"select Name,Description,NetConnectionID,Speed,AdapterTypeId,NetConnectionStatus,GUID from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2336:20231010:030802.138 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2194:20231010:030832.634 Zabbix agent item "service.info["CiscoAMP",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2465:20231010:030907.008 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2363:20231010:030922.074 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2233:20231010:030943.182 Zabbix agent item "net.if.in["{47A09CB2-AFC4-458E-8D45-C70E8EA02050}",errors]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2344:20231010:031018.543 Zabbix agent item "net.if.in["{47A09CB2-AFC4-458E-8D45-C70E8EA02050}",errors]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2341:20231010:031033.023 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2408:20231010:031038.469 Zabbix agent item "service.info["CiscoAMP",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2076:20231010:031054.081 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2325:20231010:031058.406 Zabbix agent item "perf_counter_en["\System\Threads"]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2439:20231010:031113.779 Zabbix agent item "service.info["CiscoAMP",state]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2301:20231010:031133.015 temporarily disabling Zabbix agent checks on host "CLC-01A-L3": interface unavailable
        2297:20231010:031143.487 enabling Zabbix agent checks on host "CLC-01A-L3": interface became available
        2355:20231010:031208.091 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2352:20231010:031223.130 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2121:20231010:031254.067 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2302:20231010:031312.071 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2114:20231010:031334.300 Zabbix agent item "perf_counter_en["\Memory\Free System Page Table Entries"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2449:20231010:031352.543 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2145:20231010:031353.248 Zabbix agent item "vm.memory.size[total]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2328:20231010:031428.404 Zabbix agent item "system.swap.size[,total]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2352:20231010:031435.524 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2319:20231010:031503.401 Zabbix agent item "proc.num[]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2309:20231010:031533.888 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2070:20231010:031555.293 Zabbix agent item "system.uptime" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2381:20231010:031630.071 Zabbix agent item "system.uptime" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2404:20231010:031633.084 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2357:20231010:031710.532 Zabbix agent item "perf_counter_en["\Paging file(_Total)\% Usage"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2283:20231010:031726.048 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2182:20231010:031727.451 Zabbix agent item "perf_counter_en["\Memory\Cache Bytes"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2391:20231010:031742.018 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2185:20231010:031833.156 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2269:20231010:031908.544 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2469:20231010:031923.079 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2315:20231010:031928.428 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Disk Writes/sec",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2405:20231010:031943.240 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2092:20231010:031944.059 Zabbix agent item "wmi.getall[root\cimv2,"select Name,Description,NetConnectionID,Speed,AdapterTypeId,NetConnectionStatus,GUID from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2318:20231010:032002.524 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2283:20231010:032003.644 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Disk Writes/sec",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2381:20231010:032033.664 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2222:20231010:032056.271 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk sec/Write",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2403:20231010:032112.640 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2197:20231010:032134.264 Zabbix agent item "service.info["CiscoSCMS",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2329:20231010:032152.577 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2072:20231010:032233.107 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2299:20231010:032255.487 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2299:20231010:032328.548 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2270:20231010:032343.022 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2218:20231010:032344.080 Zabbix agent item "wmi.getall[root\cimv2,"select Name,Description,NetConnectionID,Speed,AdapterTypeId,NetConnectionStatus,GUID from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2458:20231010:032402.109 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2126:20231010:032433.648 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2433:20231010:032508.055 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk sec/Write",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2311:20231010:032523.155 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2127:20231010:032548.365 Zabbix agent item "system.sw.os" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2338:20231010:032623.086 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2437:20231010:032623.464 Zabbix agent item "perf_counter_en["\Paging file(_Total)\% Usage"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2360:20231010:032645.375 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2389:20231010:032718.087 Zabbix agent item "perf_counter_en["\Paging file(_Total)\% Usage"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2317:20231010:032733.071 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2119:20231010:032835.687 Zabbix agent item "service.info["NiniteAgent",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2447:20231010:032853.056 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2234:20231010:032854.088 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2418:20231010:032912.197 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2143:20231010:032944.204 Zabbix agent item "wmi.getall[root\cimv2,"select Name,Description,NetConnectionID,Speed,AdapterTypeId,NetConnectionStatus,GUID from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2385:20231010:033002.400 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2093:20231010:033034.000 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2362:20231010:033052.069 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2096:20231010:033134.444 Zabbix agent item "perf_counter_en["\Processor Information(_total)\% Interrupt Time"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2420:20231010:033152.201 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2308:20231010:033229.440 Zabbix agent item "perf_counter_en["\Processor Information(_total)\% Privileged Time"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2336:20231010:033304.004 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk sec/Write",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2441:20231010:033322.560 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2365:20231010:033324.004 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Disk Writes/sec",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2332:20231010:033342.716 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2163:20231010:033343.056 Zabbix agent item "net.if.in["{47A09CB2-AFC4-458E-8D45-C70E8EA02050}",errors]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2435:20231010:033418.031 Zabbix agent item "net.if.in["{47A09CB2-AFC4-458E-8D45-C70E8EA02050}",errors]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2345:20231010:033433.046 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2100:20231010:033528.467 Zabbix agent item "perf_counter_en["\Memory\Cache Bytes"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2450:20231010:033543.043 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2227:20231010:033634.220 Zabbix agent item "service.info["CiscoAMP",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2159:20231010:033650.511 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk Write Queue Length",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2461:20231010:033652.480 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2089:20231010:033733.089 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2275:20231010:033808.080 Zabbix agent item "system.swap.size[,total]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2292:20231010:033823.071 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2074:20231010:033850.098 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk Write Queue Length",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2406:20231010:033912.130 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2064:20231010:033932.419 Zabbix agent item "service.info["CiscoAMP",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2363:20231010:034007.072 Zabbix agent item "agent.ping" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2425:20231010:034022.300 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2186:20231010:034134.272 Zabbix agent item "perf_counter_en["\Processor Information(_total)\% Privileged Time"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2264:20231010:034152.071 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2099:20231010:034154.172 Zabbix agent item "system.swap.size[,total]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2263:20231010:034229.844 Zabbix agent item "agent.version" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2314:20231010:034232.223 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2176:20231010:034254.173 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2318:20231010:034309.464 Zabbix agent item "system.swap.size[,total]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2312:20231010:034312.197 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2205:20231010:034334.072 Zabbix agent item "service.info["CiscoSCMS",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2378:20231010:034409.608 Zabbix agent item "agent.ping" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2262:20231010:034412.199 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2281:20231010:034444.243 Zabbix agent item "agent.ping" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2417:20231010:034519.524 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2259:20231010:034522.401 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2142:20231010:034557.326 Zabbix agent item "perf_counter_en["\Paging file(_Total)\% Usage"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2405:20231010:034612.094 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2095:20231010:034633.534 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2317:20231010:034708.063 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Disk Writes/sec",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2426:20231010:034728.028 temporarily disabling Zabbix agent checks on host "CLC-01A-L3": interface unavailable
        2304:20231010:034843.377 enabling Zabbix agent checks on host "CLC-01A-L3": interface became available
        2464:20231010:034903.427 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2357:20231010:034933.444 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2173:20231010:034954.022 Zabbix agent item "system.swap.size[,total]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2418:20231010:035029.426 Zabbix agent item "agent.ping" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2453:20231010:035032.069 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2075:20231010:035128.456 Zabbix agent item "perf_counter_en["\Memory\Cache Bytes"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2396:20231010:035143.119 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2072:20231010:035143.347 Zabbix agent item "net.if.in["{47A09CB2-AFC4-458E-8D45-C70E8EA02050}",errors]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2432:20231010:035218.228 Zabbix agent item "system.sw.os" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2277:20231010:035233.365 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2298:20231010:035238.212 Zabbix agent item "service.info["Spooler",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2356:20231010:035253.045 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2074:20231010:035254.076 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2278:20231010:035312.576 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2258:20231010:035334.332 Zabbix agent item "perf_counter_en["\Memory\Free System Page Table Entries"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2309:20231010:035352.732 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2228:20231010:035354.108 Zabbix agent item "system.swap.size[,total]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2428:20231010:035429.520 Zabbix agent item "system.uptime" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2433:20231010:035432.067 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2097:20231010:035525.932 Zabbix agent item "perf_counter_en["\Memory\Cache Bytes"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2308:20231010:035543.108 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2231:20231010:035544.375 Zabbix agent item "wmi.getall[root\cimv2,"select Name,Description,NetConnectionID,Speed,AdapterTypeId,NetConnectionStatus,GUID from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2344:20231010:035619.180 Zabbix agent item "wmi.getall[root\cimv2,"select Name,Description,NetConnectionID,Speed,AdapterTypeId,NetConnectionStatus,GUID from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2419:20231010:035622.212 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2407:20231010:035654.316 Zabbix agent item "wmi.getall[root\cimv2,"select Name,Description,NetConnectionID,Speed,AdapterTypeId,NetConnectionStatus,GUID from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2409:20231010:035712.608 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2101:20231010:035734.003 Zabbix agent item "perf_counter_en["\Memory\Free System Page Table Entries"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2357:20231010:035752.256 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2387:20231010:035829.724 Zabbix agent item "net.if.in["{47A09CB2-AFC4-458E-8D45-C70E8EA02050}",errors]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2323:20231010:035851.775 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2350:20231010:035924.003 Zabbix agent item "service.info["CiscoSCMS",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2368:20231010:035942.304 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored​
      And here's what I see around the 5:00 mark:
      2410:20231010:050008.088 Zabbix agent item "agent.version" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2313:20231010:050023.166 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2353:20231010:050043.383 Zabbix agent item "proc.num[]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2308:20231010:050118.204 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2368:20231010:050133.125 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2209:20231010:050156.128 Zabbix agent item "vm.memory.size[used]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2341:20231010:050212.628 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2227:20231010:050233.376 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2314:20231010:050308.286 Zabbix agent item "system.uptime" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2341:20231010:050323.061 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2093:20231010:050347.358 Zabbix agent item "perf_counter_en["\System\Threads"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2428:20231010:050402.131 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2221:20231010:050434.300 Zabbix agent item "service.info["CiscoSCMS",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2318:20231010:050452.289 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2244:20231010:050454.188 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2264:20231010:050512.288 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2123:20231010:050533.152 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2416:20231010:050608.135 Zabbix agent item "system.swap.size[,total]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2341:20231010:050623.453 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2291:20231010:050648.446 Zabbix agent item "perf_counter_en["\Memory\Free System Page Table Entries"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2418:20231010:050703.535 Zabbix agent item "system.swap.size[,total]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2425:20231010:050733.637 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2202:20231010:050757.372 Zabbix agent item "perf_counter_en["\Paging file(_Total)\% Usage"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2396:20231010:050812.031 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2195:20231010:050833.083 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2261:20231010:050908.198 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2295:20231010:050923.032 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2285:20231010:050943.163 Zabbix agent item "service.info["NiniteAgent",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2248:20231010:050958.005 Zabbix agent item "agent.version" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2403:20231010:051033.118 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2320:20231010:051033.217 Zabbix agent item "service.info["CiscoAMP",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2347:20231010:051108.224 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk sec/Write",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2469:20231010:051123.052 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2307:20231010:051128.163 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Disk Writes/sec",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2265:20231010:051143.096 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk sec/Write",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2468:20231010:051143.111 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2305:20231010:051223.007 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Disk Writes/sec",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2283:20231010:051253.889 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2443:20231010:051318.483 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Disk Writes/sec",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2373:20231010:051333.038 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2226:20231010:051334.368 Zabbix agent item "perf_counter_en["\Memory\Free System Page Table Entries"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2448:20231010:051352.068 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2359:20231010:051353.851 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Disk Writes/sec",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2300:20231010:051423.489 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2237:20231010:051453.318 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk sec/Read",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2364:20231010:051528.311 Zabbix agent item "perf_counter_en["\Processor Information(_total)\% DPC Time"]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2386:20231010:051543.105 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2415:20231010:051548.273 Zabbix agent item "net.if.in["{47A09CB2-AFC4-458E-8D45-C70E8EA02050}",dropped]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2350:20231010:051603.568 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk sec/Read",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2384:20231010:051633.793 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2123:20231010:051654.087 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2267:20231010:051712.288 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2146:20231010:051733.708 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2319:20231010:051808.012 Zabbix agent item "system.uptime" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2273:20231010:051823.239 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2342:20231010:051843.325 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2465:20231010:051913.793 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2417:20231010:051938.600 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2394:20231010:051953.426 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2256:20231010:051954.089 Zabbix agent item "system.swap.size[,total]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2355:20231010:052013.750 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2362:20231010:052029.603 Zabbix agent item "system.swap.size[,total]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2367:20231010:052035.456 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2356:20231010:052108.531 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2298:20231010:052123.057 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2130:20231010:052143.074 Zabbix agent item "net.if.in["{47A09CB2-AFC4-458E-8D45-C70E8EA02050}",errors]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2363:20231010:052218.280 Zabbix agent item "net.if.in["{47A09CB2-AFC4-458E-8D45-C70E8EA02050}",errors]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2327:20231010:052238.243 temporarily disabling Zabbix agent checks on host "CLC-01A-L3": interface unavailable
        2289:20231010:052813.024 enabling Zabbix agent checks on host "CLC-01A-L3": interface became available
        2434:20231010:052833.328 Zabbix agent item "perf_counter_en["\Processor Information(_total)\% Interrupt Time"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2262:20231010:052908.008 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk sec/Write",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2318:20231010:052923.025 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2066:20231010:052944.049 Zabbix agent item "wmi.getall[root\cimv2,"select Name,Description,NetConnectionID,Speed,AdapterTypeId,NetConnectionStatus,GUID from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2398:20231010:053019.232 Zabbix agent item "agent.version" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2294:20231010:053034.036 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2364:20231010:053114.020 Zabbix agent item "wmi.getall[root\cimv2,"select Name,Description,NetConnectionID,Speed,AdapterTypeId,NetConnectionStatus,GUID from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2267:20231010:053132.480 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2202:20231010:053132.684 Zabbix agent item "perf_counter_en["\Processor Information(_total)\% DPC Time"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2343:20231010:053154.116 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2230:20231010:053234.088 Zabbix agent item "service.info["CiscoSCMS",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2395:20231010:053252.068 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2256:20231010:053334.121 Zabbix agent item "perf_counter_en["\Processor Information(_total)\% User Time"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2426:20231010:053352.511 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2426:20231010:053429.567 Zabbix agent item "system.cpu.load[all,avg15]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2310:20231010:053444.073 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2326:20231010:053504.283 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2389:20231010:053522.399 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2170:20231010:053544.167 Zabbix agent item "wmi.getall[root\cimv2,"select Name,Description,NetConnectionID,Speed,AdapterTypeId,NetConnectionStatus,GUID from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2403:20231010:053602.120 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2130:20231010:053604.102 Zabbix agent item "perf_instance_en.discovery[PhysicalDisk]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2431:20231010:053622.053 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2224:20231010:053643.049 Zabbix agent item "net.if.in["{47A09CB2-AFC4-458E-8D45-C70E8EA02050}",errors]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2297:20231010:053718.427 Zabbix agent item "net.if.in["{47A09CB2-AFC4-458E-8D45-C70E8EA02050}",errors]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2438:20231010:053733.053 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2120:20231010:053754.056 Zabbix agent item "system.swap.size[,total]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2319:20231010:053812.068 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2255:20231010:053833.283 Zabbix agent item "service.info["CiscoOrbital",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2341:20231010:053855.230 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2071:20231010:053925.399 Zabbix agent item "perf_counter_en["\Memory\Cache Bytes"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2320:20231010:053940.024 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2139:20231010:053940.504 Zabbix agent item "perf_counter_en["\Memory\Free System Page Table Entries"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2349:20231010:054002.623 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2120:20231010:054050.480 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk Write Queue Length",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2367:20231010:054112.451 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2149:20231010:054132.633 Zabbix agent item "perf_counter_en["\Processor Information(_total)\% User Time"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2345:20231010:054207.007 Zabbix agent item "vm.memory.size[total]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2281:20231010:054222.027 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2110:20231010:054254.112 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2402:20231010:054329.240 Zabbix agent item "perf_counter_en["\System\Context Switches/sec"]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2308:20231010:054332.227 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2222:20231010:054357.767 Zabbix agent item "perf_counter_en["\Paging file(_Total)\% Usage"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2284:20231010:054412.368 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2170:20231010:054532.280 Zabbix agent item "perf_counter_en["\Processor Information(_total)\% Interrupt Time"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2103:20231010:054548.148 Zabbix agent item "system.sw.os" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2438:20231010:054602.496 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2464:20231010:054623.113 Zabbix agent item "system.sw.os" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2352:20231010:054658.248 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk Read Queue Length",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2423:20231010:054718.083 temporarily disabling Zabbix agent checks on host "CLC-01A-L3": interface unavailable
        2298:20231010:054833.024 enabling Zabbix agent checks on host "CLC-01A-L3": interface became available
        2274:20231010:054853.400 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk Read Queue Length",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2266:20231010:054923.456 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2146:20231010:054958.478 Zabbix agent item "agent.version" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2368:20231010:055013.299 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2202:20231010:055034.087 Zabbix agent item "service.info["CiscoSCMS",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2306:20231010:055052.669 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2217:20231010:055054.056 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\% Idle Time",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2409:20231010:055129.523 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Disk Writes/sec",60]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2461:20231010:055132.069 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2230:20231010:055153.244 Zabbix agent item "vm.memory.size[total]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2369:20231010:055228.481 Zabbix agent item "vm.memory.size[total]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2463:20231010:055243.071 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2455:20231010:055248.088 Zabbix agent item "service.info["QualysAgent",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2399:20231010:055323.027 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2377:20231010:055323.051 Zabbix agent item "service.info["Zabbix Agent 2",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2365:20231010:055353.280 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2285:20231010:055418.149 Zabbix agent item "service.info["QualysAgent",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2432:20231010:055433.034 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2122:20231010:055434.072 Zabbix agent item "service.info["CiscoAMP",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2464:20231010:055452.447 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2111:20231010:055528.378 Zabbix agent item "perf_counter_en["\Memory\Cache Bytes"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2316:20231010:055543.330 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2343:20231010:055603.351 Zabbix agent item "perf_counter_en["\Memory\Cache Bytes"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2267:20231010:055638.088 Zabbix agent item "service.info["CiscoAMP",state]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2326:20231010:055653.261 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2328:20231010:055658.004 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Disk Reads/sec",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2379:20231010:055713.025 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2121:20231010:055744.039 Zabbix agent item "wmi.getall[root\cimv2,"select Name,Description,NetConnectionID,Speed,AdapterTypeId,NetConnectionStatus,GUID from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2170:20231010:055800.508 Zabbix agent item "agent.ping" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2387:20231010:055802.527 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2161:20231010:055834.363 Zabbix agent item "service.info["CiscoSCMS",state]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2279:20231010:055852.927 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2139:20231010:055853.111 Zabbix agent item "perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk sec/Read",60]" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds
        2345:20231010:055928.301 Zabbix agent item "perf_counter_en["\Memory\Cache Bytes"]" on host "CLC-01A-L3" failed: another network error, wait for 15 seconds
        2444:20231010:055935.299 resuming Zabbix agent checks on host "CLC-01A-L3": connection restored
        2080:20231010:055958.248 Zabbix agent item "agent.version" on host "CLC-01A-L3" failed: first network error, wait for 15 seconds​
      So I understand that for some reason these checks are timing out and that's causing the agent to become unavailable (or vice versa). However, I'm not sure what needs to be done to rectify this issue. I appreciate any help you can provide!
      • vijayk
        • May 2023
        • 305
        2023/10/10 03:00:42.599627 [101] sending of heartbeat message for [CLC-01A-L3] started to fail​
        Error says active check goes failed.
        Can you confirm the Hostname and ServerActive IP in .conf file in agent ?
          dieselfluxcapacitor commented
          The weird thing is that this host never had an active agent template applied, so I'm not sure why it was trying to query for active checks. Of course it will fail - there aren't any checks to be found!
        • Jul 2023
        • 11
        Thanks for all the help. Ultimately, I determined that there were too many issues with the server (and I needed to reconfigure the solution architecture anyway) so I ended up blowing it away and starting over. Fortunately, on the second attempt, I am no longer seeing these issues.
        • vijayk
          • May 2023
          • 305
          Nice to hear that issue is no remain.
            I agree. I think the other change that helped greatly was moving away from using the passive Zabbix agent. Instead, I've shifted all possible hosts over to active monitoring which has drastically improved the performance of my Zabbix server.
        • vijayk
          • May 2023
          • 305
          That's great.
