Problem with Agent 2 Status
  • Saftnase
    • Jul 2006
    • 30
    i am rolling out the Zabbix Agent 2 and found something strange.
    The Agent ist configured for Active Checks and it works like a charm, but in the Frontend every Host discovered by Autoregistration shows the Agent Passive Checks as unavailiable and Active Checks as Availiable
    But as in the Docs the Agent should be able to act in active and passive mode.
    So what is going on ?
  • Answer selected by Saftnase at 16-10-2023, 09:53.
    cyber
    • 5004
    Simple, you have only active checks, thus, it shows that active checks avaialble. Add 1 passive check and also passive checks "become available".
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      It's described here: https://www.zabbix.com/documentation...hosts#overview
      Basically, you need to remove the Agent interface and then the icon should become green. There is a change request for Zabbix to do that automatically, feel free to follow and vote: https://support.zabbix.com/browse/ZBXNEXT-8223
        • 5004
        • Saftnase
          • Jul 2006
          • 30
          cyber Well adding a generic passive check did the trick, despite it makes sense and is kind a logic to display the host as unavail when an Agent Interface is set but no passive checks configured it is a confusing behavior as the Agent is availiable. :-)
