HTTPS check not working properly
  • slartibartfast
    • Aug 2016
    • 11
    Using Zabbix 3.0.3, official rpm build on CentOS 7, and for some servers HTTPS check (stock Template) is not working, and for some does.
    Remote server does run Apache on https/443 port, telnet from Zabbix works to remote server, I can see in Apache ssl logs successful accesses from Zabbix server, but still it triggers as https is down:
    [ commands ran from zabbix server]
    $ zabbix_get -s 192.168.0.22 -k "net.tcp.service[https]"
    0
    $ telnet 192.168.0.22 https
    Trying 192.168.0.22...
    Connected to 192.168.0.22.
    Escape character is '^]'.
    Apache logs on 192.168.0.22 shows
    192.168.0.14 - - [28/Aug/2016:13:31:53] "HEAD / HTTP/1.1" 200 -
    Strange thing is that same HTTPS check works for some servers without issues. Also, firewall is not deployed at all.
    Any thoughts?
  • LenR
    • Sep 2009
    • 1011
    net.tcp.service is a "simple check", I think zabbix_get is for Zabbix Agent items only. Try net.tcp.listen(443).
    • slartibartfast
      • Aug 2016
      • 11
      Yes -- you are correct.
      Still, somehow this https check works for some servers and not for others.
      • Atsushi
        • Aug 2013
        • 2028
        https is not bound by specifying the ip address?
        If you specify the IP address are bound, please try to also specify the IP address in the argument.
        ex.
        net.tcp.service[https,<ip address>]
        • LenR
          • Sep 2009
          • 1011
          Ok, net.tcp.service is an agent item. See the doc at https://www.zabbix.com/documentation...s#https_checks
          Try debugging with curl and/or tcpdump from the same network perspective as this test. The various TLS exploits have caused some web servers to require TLS versions that curl doesn't support.
          We use Redhat, I had to install a local version of curl on my zabbix proxies until RHEL put newer TLS support in the channel for curl.
          Note that doc says https isn't supported for windows agents.
          Sorry for the bad info before.
          • slartibartfast
            • Aug 2016
            • 11
            Indeed, using curl it hits some error:
            $ curl https://192.168.0.22
            curl: (35) SSL received a record that exceeded the maximum permissible length.
            Other than this, this server is working for years with success in regard serving from https port.
