Memory monitoring
  • jpgosselin
    • Jan 2024
    Memory monitoring
    Hi i want to monitor some hosts memory usage in flat values instead of percentage but can't seem to see anywhere possible. Could someone please help
  • LenR
    • Sep 2009
    • 1011
    vm.memory.size[<mode>]
    ​mode can be total (default), active, anon, buffers, cached, exec, file, free, inactive, pinned, shared, slab, wired, used, pused (used, percentage), available, or pavailable (available, percentage)​
    The futility is that OS's want to use all the memory they can to make life better, for example, disk cache. Unused memory is burying money in the back yard. You have it, it's not working for you. I always enable swap, then watch swap rates. Let the arguments begin :-)
