programmitically usage of maintenance.update in C#, .NET 8 (ZABBIX version 6.0)
  • Nerd24
    • Jan 2024
    Hello there,
    maybe I'm right here. I've written a small application, which communicates with a ZABBIX server on version 6.0 by using
    C# in .NET core 8 with JSON.
    This includes to list all stored hosts, creating a maintenance and updating a maintenance.
    Unlike the last one everything works fine. And this is the point, where I'm now out of ideas what to do.
    Based on the API documentation => https://www.zabbix.com/documentation...tenance/update
    I need the property timeperiods to say when an active maintenance shall be terminated earlier or later, however, ZABBIX reports:
        "jsonrpc": "2.0",
            "error": {
             "code": -32600,
             "message": "Invalid request.",
             "data": "Invalid parameter \"/\": unexpected parameter \"timeperiods\"."
    "id": 3
    So, I'm getting the information, that the given request with timeperiods as property won't work. When I'm running the JSON pattern without this property, then the command returns the expected result, like:
        "jsonrpc": "2.0",
        "result": {
            "maintenanceids": [
                "12"
        "id": 1
    but the active maintenance is still running until the defined timestamp has been reached.
    The skeleton for maintenance.update in C# looks like this:
        public class MaintenanceUpdate {
            public String? jsonrpc;
            public String? method;
            public Parameters? @params;
            public TimePeriod? timeperiods;                 // This might be wrong for the API?
            public String? auth;
            public double id;
            public class Parameters {
                public String? maintenanceid;
                public List<HostSettings>? hosts;
            public class HostSettings {
                public String? hostid;
            public class TimePeriod {
                public int period;
                public int timeperiod_type;
                public uint start_date;
                public int start_time;
                public int every;
                public int dayofweek;
                public int day;
                public int month;
    I'm using this class pattern above here:
    using(StreamWriter sw = new StreamWriter(httpWebRequest.GetRequestStream())) {
                    MaintenanceUpdate mUpdate = new MaintenanceUpdate() {
                                    jsonrpc = "2.0",
                                    method = "maintenance.update",
                                    id = 3,
                                    auth = < top secret key here :-) >,
                                    @params = new MaintenanceUpdate.Parameters() {
                                        maintenanceid = hostToUse.maintenanceid,
                                        hosts = new List<MaintenanceUpdate.HostSettings>() {
                                            new MaintenanceUpdate.HostSettings() {
                                                hostid = hostID.ToString()
                                    timeperiods = new MaintenanceUpdate.TimePeriod() {
                                        period = 0
                    sw.Write(JsonConvert.SerializeObject(mUpdate));
    MaintenanceUpdateResponse? responseMaintenanceUpdate;
    httpResponse = (HttpWebResponse)httpWebRequest.GetResponse();
    using(StreamReader sr = new StreamReader(httpResponse.GetResponseStream())) {
                    String result = sr.ReadToEnd();
                    Console.WriteLine(result);                      // <-- prints the error message [...]unexpected parameter \"timeperiods\"."[...]
                    responseMaintenanceUpdate = JsonConvert.DeserializeObject<MaintenanceUpdateResponse>(result);
    So, the JSON format for maintenance.update looks like this:
        "jsonrpc": "2.0",
        "method": "maintenance.update",
        "params": {
            "maintenanceid": "12",
            "hosts": [
                    "hostid": "< ID of the host >"
          "timeperiods": {
               "period": 0,
               "timeperiod_type": 0,
                "start_date": 0,
                "start_time": 0,
                "every": 0,
                "dayofweek": 0,
                "day": 0,
                "month": 0
    "auth": "< super secret key :-) >",
    "id": 3
    Do I miss something? Is there maybe an another way to handle this?
    Thanks in advise. (:
    Greetings
    • 4996
    I am not much of a programmer, but shouldn't timeperiods be part of parameters? Currently seems it falls out of "params: {}" and thus you get errors...
    example is here... https://www.zabbix.com/documentation...tenance/create
