Trigger not firing when maintenance expires - 3.2
  • ahahum
    • Jan 2009
    • 79
    Recently upgraded to 3.2. I am not sure if it began right after, but I did not notice it prior to the upgrade.
    I had 5 triggers that went to problem overnight, but this AM when the recurring maintenance period expired, the actions were not executed like they have always done in the past.
    Anyone else having this issue with 3.2?
  • Atsushi
    • Aug 2013
    • 2028
    Does this specification change does not match?
    • ahahum
      • Jan 2009
      • 79
      I had my options for the actions set to if the host was NOT in maintenance. That is not necessary now with the new option you pointed out. Thank you.
      I am testing and will see if that fixes the issue.
