No results in Last value
  • Danio9004
    • Sep 2023
    • 13
    In Zabbix version 6, I have created the following:
    • Discovery rule:
      discovery.webservice[{$ENV}]
      with an update interval of 60 minutes.
    • Item prototypes:
      monitor.webservice_status_code[{$ENV},{#SVC}]
      with an update interval of 15 minutes.
    • Trigger prototypes:
      last(/APP-TERRA Web Services/monitor.webservice_status_code[{$ENV},{#SVC}])<>200
    The Python script checking returns a status code of 200. The following steps are invoked:
    1. UserParameter for discovery:
      discovery.webservice[*]
    2. , running the command:
      sudo -u dsadm python3 /etc/zabbix/Scripts/zbx_monitor_web_svcs.py -e $1 -o discover[*]
    3. UserParameter for monitoring output:
       monitor.webservice_output[*]
    4. , running the command:
      sudo -u dsadm python3 /etc/zabbix/Scripts/zbx_monitor_web_svcs.py -e $1 -o status -s $2 -t output[*]
    5. UserParameter for monitoring status code:
      monitor.webservice_status_code[*]
    6. , running the command:
      sudo -u dsadm python3 /etc/zabbix/Scripts/zbx_monitor_web_svcs.py -e $1 -o status -s $2 -t code
      (this returns 200)
    Item prototypes are created, but there is no data available.
    ​What is wrong? Help
    • 4996
    Is something returned if try with "zabbix_get" or "zabbix_agent -t" ?
    • Danio9004
      • Sep 2023
      • 13
      Unfortunately, I don't have the ability to do this.
      However, for another service that uses the same trigger and item returns the data correctly.​
      On the server, the python script returns a status of 200 for this Client_F5.​
