agent-base in vCenter?
  • m_pahlevanzadeh
    • Jun 2022
    • 28
    According to https://bestmonitoringtools.com/vmwa...er-vm-vsphere/ I have to set agent for VMware,
    Does vCeneter have agent of zabbix by default?
  • jnsvano
    • Feb 2013
    • 144
    No need to install agent:
    • m_pahlevanzadeh
      • Jun 2022
      • 28
      I don't want to monitor VMs, I need to monitor ESXis and vCeneter.
      • jnsvano
        • Feb 2013
        • 144
        Nobody obliges you to monitor only VM, just disable the discovery rule ("Discovery of guest virtual machines" or whatever it is).
        • m_pahlevanzadeh
          • Jun 2022
          • 28
          According to URL of doc, I have to set agent, It's my main question.
            • 4996
            I don't see any note on that page, that says you have to install zabbix agent on your vCenter host. Step3 a) instructs you to create host in zabbix and add credentials.. there is nothing about installing an agent...
