SNMP v3 Cisco C9300-48U
  • TH001
    • Dec 2023
    I have been searching all over and various forums to see if anyone has got SNMP v3 working with Cisco C9300-48u switch, so far I cannot find any success stories.
    Is there anyone who has this working? Have you got your Zabbix monitoring Cisco C9300 (or C9400) switches using SNMP v3 successfully?
    Version 2 is straight forward but v3....why is it so difficult? ...unless I'm missing something?
    If you do have it working, could you please let me know how, it really would be a big relief
    • 4996
    What is it, that does not work out ? Considering v2 and v3 from contents point of view are same, v3 just adds a layer of security, it should not be rocket surgery? If it is a relief for you, I can say it works for us... I did not do it.. did not touch any switch nor did configure any template. Our network people did it by themselves...
    • TH001
      • Dec 2023
      When I enter the below SNMP v3 config on the Cisco C9300 switch the 'SNMP Availability' status (under Monitoring >> Hosts turn Red and no data is pulled from the switch to Zabbix. The moment I change to SNMP v2 the SNMP Availability status changes to green and all data is pulled through.
      snmp-server group <group name> v3 priv read <view name>
      snmp-server user <snmp user> <group name> v3 auth sha <auth pw> priv aes 256 <priv pw>
      snmp-server view <view name> iso included
      On Zabbix :
      Context Name: blank
      Security name: <snmp user>
      Security Level: authPriv
      Authentication Protocol: SHA1
      Authentication Password: <auth pw>
      Privacy Protocol: AES256
      Privacy Passphrase: <priv pw>
      Under Data Collection >> Hosts the error message says 'Timeout while connecting to <ip address of switch:161>
      There is no firewall or access-list on the switch. So what did you do to make it work on SNMP v3? what switch model are you using?
      • TH001
        • Dec 2023
        Also I have similar setting on Solarwind for v3 and it works with no issues.
          • 4996
          From command line with snmpwalk it also fails? Do you have time sync in place, it is very important for v3 to have all times in sync.
          • TH001
            • Dec 2023
            Yes snmpwalk also times out on v3 (v2 is good). I'll check time sync. Also tried changing Engine ID to make sure.
