Guyz,
I am using Zabbix 2.4 for over a year now and in the month of October I had faced this weird problem for High Bandwidth Consumption.
The Zabbix server is running over AWS EC2 Instance. The current setup monitors instance in the private subnet and as well in the fewer instance which are public.
Strangely, last month there was a huge data transfer occurred from the Zabbix server around 3 TB . Can you guyz assist me on why this heavy data transfer is getting generated. I have also used "iftop" utililty to view the current on going session but didn't find anything good . Also, the current consumption is around 1-2 MB per minute.
eth0 Link encap:Ethernet HWaddr 0A:FE:62:48:8E:2F
inet6 addr: fe80::8fe:62ff:fe48:8e2f/64 Scope:Link
UP BROADCAST RUNNING PROMISC MULTICAST MTU:9001 Metric:1
RX packets:1134496296 errors:0 dropped:0 overruns:0 frame:0
TX packets:8467913192 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:83226840430 (77.5 GiB) TX bytes:7107123475059 (6.4 TiB)
Interrupt:155
Interrupt:155
