Get value from agent failed: cannot connect
  • Zululander
    • May 2024
    I am running the server in a docker container. I have added a single host and this is working fine. The zabbix server (192.168.10.11) is however reporting:
    Get value from agent failed: cannot connect to [[192.168.10.11]:10050]: [111] Connection refused
  • Avinasha
    • Jan 2018
    • 40
    I prefer installing telnet on the zabbix server and then try to use it to make sure the server can reach the agent. telnet <Agent IP or Hostname 10050>
    telnet 10.10.10.1 10050
    Mostly these errors occur when there is a block in its path. Mostly its your firewall that needs a hole to be punched in it.
    If its windows, try allowing the exe through it.
    • Zululander
      • May 2024
      But what confuses me is the host 192.168.10.11 is the zabbix server so why would it not be able to reach itself?
      • Markku
        • Sep 2018
        • 1784
        Do you have a Zabbix agent running on the Zabbix server container?
        If not, then it is natural that you get an error when trying to connect to the nonexistent agent port.
        Markku
