About install Zabbix 3.2 on Ubuntu 16.04
  • tariku
    • Nov 2016
    I just made a fresh zabbix install on Ubuntu 16.04. When i enter dashboard i see "Zabbix server is not running" message below and dashboard says zabbix server value No.
    I inspected logs and i can't see any error.
    Could you please some one help me.
    Regards,
  • m.flier
    • Nov 2016
    Agent not running
    Probably the zabbix agent is not running on your server.
    Test this by running the following shell command:
    service --status-all
    Result:
    [ - ] zabbix-agent
    [ - ] zabbix-server
    Server might be running, but the agent probably not.
    run:
    sudo service zabbix-server start
    sudo service zabbix-agent start
    But after reboot the services might not autostart. Run the following to adjust:
    sudo update-rc.d zabbix-server defaults
    sudo update-rc.d zabbix-agent defaults
    sudo update-rc.d zabbix-server enable
    sudo update-rc.d zabbix-agent enable
    • tariku
      • Nov 2016
      Thank you for help. It looks works now. Now i have another problem, I installed first agent on another Ubuntu 16.04 and service looks fine. But i didn't see any info on zabbix-server.
      Do you have any idea for that?
      Thanks.
      • Atsushi
        • Aug 2013
        • 2028
        If you just installed the Zabbix agent on the target,
        you do not need to check the status of zabbix-server on that server.
        • tariku
          • Nov 2016
          No, i mean server doesn't get any data from agent.
          • Atsushi
            • Aug 2013
            • 2028
            Is the Zabbix agent in the LISTEN state with the IP that the Zabbix server can access?
            Please show me the execution result of the following command.
            $ netstat -ta
            • glebs.ivanovskis
              • Jul 2015
              • 237
              If you see "Zabbix server is not running" then you probably misconfigured server listen port when you were setting up frontend. Or someone (selinux?) is preventing frontend from connecting to server listen port.
              • LenR
                • Sep 2009
                • 1011
                selinux can cause that on rhel/cent
