Broken Packages while updating from 6.4 to 7
  • ericdano
    • Jun 2023
    Any ideas how to fix this? Running Ubuntu 22.04
    # apt-get -f install --only-upgrade zabbix-server-mysql zabbix-frontend-php zabbix-agent
    Reading package lists... Done
    Building dependency tree... Done
    Reading state information... Done
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
    zabbix-agent : Depends: libc6 (>= 2.38) but 2.35-0ubuntu3.8 is to be installed
    Depends: libcurl4t64 (>= 7.16.2) but it is not installable
    Depends: libldap2 (>= 2.6.2) but it is not installable
    Depends: libssl3t64 (>= 3.0.0) but it is not installable
    zabbix-server-mysql : Depends: libc6 (>= 2.38) but 2.35-0ubuntu3.8 is to be installed
    Depends: libcurl4t64 (>= 7.16.3) but it is not installable
    Depends: libevent-2.1-7t64 (>= 2.1.8-stable) but it is not installable
    Depends: libevent-pthreads-2.1-7t64 (>= 2.1.8-stable) but it is not installable
    Depends: libopenipmi0t64 (>= 2.0.33) but it is not installable
    Depends: libsnmp40t64 (>= 5.9.4+dfsg) but it is not installable
    E: Unable to correct problems, you have held broken packages.
  • Markku
    • Sep 2018
    • 1784
    I believe the "--only-upgrade" option prevents apt-get from installing the new packages, just leave it out.
    Markku
    • hubertsvk
      • Jul 2019
      • 15
      Markku
      Hi, I have the same problem but your solution does not helped
      root@root:/home/zabbix# apt-get install zabbix-server-mysql zabbix-frontend-php zabbix-agent
      zabbix-frontend-php is already the newest version (1:7.0.0-1+ubuntu22.04).
      zabbix-agent : Depends: libc6 (>= 2.34) but 2.31-0ubuntu9.16 is to be installed
      Depends: libldap-2.5-0 (>= 2.5.4) but it is not installable
      Depends: libssl3 (>= 3.0.0~~alpha1) but it is not installable
      zabbix-server-mysql : Depends: libc6 (>= 2.34) but 2.31-0ubuntu9.16 is to be installed
      Depends: libodbc2 (>= 2.3.1) but it is not installable
      Depends: libopenipmi0 (>= 2.0.29) but 2.0.27-0ubuntu2 is to be installed
      Depends: libsnmp40 (>= 5.9.1+dfsg) but it is not installable
      • Markku
        • Sep 2018
        • 1784
        What does
        apt-get update
        apt-get upgrade
        say to you?
        Markku
        • ddoldersum
          • Apr 2021
          Same issue here when trying to upgrade
          So zabbix-agent and zabbix-server-mysql are not being installed during the upgrade
          Depends: libodbc2 (>= 2.3.1) but it is not going to be installed
          • Markku
            • Sep 2018
            • 1784
            So, what does
            apt-get update
            apt-get upgrade
            say to you?
            Markku
            • ddoldersum
              • Apr 2021
              Everything for version 7 is installed except for the agent and mysql update. Which results in the DB not upgrading.
              So when I do a apt update it shows the agent and mysql
              When I then choose to upgrade I get the results as shown in my previous post.
              • troffasky
                • Jul 2008
                • 640
                I upgraded from 6.0 to 7.0 yesterday on Ubuntu 22.04 with no issues whatsoever.
                # apt show libc6 zabbix-server-mysql | egrep 'Version|Depends|Package:|APT-Sources'
                Package: libc6
                Version: 2.35-0ubuntu3.8
                Depends: libgcc-s1, libcrypt1 (>= 1:4.4.10-10ubuntu4)
                APT-Sources: http://gb.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
                Package: zabbix-server-mysql
                Version: 1:7.0.0-1+ubuntu22.04
                Pre-Depends: debconf
                Depends: libc6 (>= 2.34), libcurl4 (>= 7.16.3), libevent-2.1-7 (>= 2.1.8-stable), libevent-pthreads-2.1-7 (>= 2.1.8-stable), libldap-2.5-0 (>= 2.5.4), libmysqlclient21 (>= 8.0.11), libodbc2 (>= 2.3.1), libopenipmi0 (>= 2.0.29), libpcre2-8-0 (>= 10.22), libsnmp40 (>= 5.9.1+dfsg), libssh-4 (>= 0.8.0), libssl3 (>= 3.0.0~~alpha1), libxml2 (>= 2.7.4), zlib1g (>= 1:1.2.0), mysql-client | virtual-mysql-client | default-mysql-client, fping, adduser, lsb-base
                APT-Sources: https://repo.zabbix.com/zabbix/7.0/ubuntu jammy/main amd64 Packages
                On this system, zabbix-server-mysql depends on libc6 (>= 2.34), but on yours it's >= 2.38? I think you've installed Zabbix from the wrong repo for your distro.
                • glen442
                  • Jun 2024
                  Hi, I had the same problem.
                  It was caused by me accidentally adding the sources for 24.04 not 22.04.
                  verification:
                  cat /etc/apt/sources.list.d/zabbix.list
                  If the output contains a line like this:
                  deb https://repo.zabbix.com/zabbix/7.0/ubuntu noble main
                  Those are the incorrect sources.
                  To fix:
                  sudo rm -Rf /etc/apt/sources.list.d/zabbix.list
                  wget https://repo.zabbix.com/zabbix/7.0/ubuntu/pool/main/z/zabbix-release/zabbix-release_7.0-1+ubuntu22.04_all.debdpkg -i zabbix-release_7.0-1+ubuntu22.04_all.deb
                  sudo dpkg -i zabbix-release_7.0-1+ubuntu22.04_all.deb
                  # type whatever letter installs the package maintainers version
                  #continue upgrade - (replace mysql with whichever db you are using)
                  apt-get install --only-upgrade zabbix-server-mysql zabbix-frontend-php zabbix-agent
                  • glen442
                    glen442 commented
                    I forgot to include "sudo apt-get update" and missed the sudo off the install command. There doesn't seem to be an edit link?
                • Tristis Oris
                  • Sep 2015
                  • 66
                  With 7.2.1 update my sources list been changed to "jammy" on ubuntu24.
                  so i got same error.
                  zabbix-agent : Depends: libldap-2.5-0 (>= 2.5.4) but it is not installable
                  zabbix-server-pgsql : Depends: libldap-2.5-0 (>= 2.5.4) but it is not installable
