Zabbix 6.4.16 Not Available for Ubuntu Yet?
  • bdobson
    • Feb 2024
    • 19
    Hopefully, I'm not missing something but I see that verison 6.4.16 has been released but when I check on Ubuntu 22.04 it says nothings available?
    When I manually check https://repo.zabbix.com/zabbix/6.4/ubuntu/ is shows the repos have not been updated yet.
    • 5004
    Everything 6.4.16 has been updated on 17th of June...
    • Markku
      • Sep 2018
      • 1788
      Related?
      ZBX-24678 (shortlink), "Zabbix Debian repository was not properly udated after release of 6.0.31 and 6.4.16 versions"
      Markku
      • bdobson
        • Feb 2024
        • 19
        Originally posted by Markku
        Related?
        Markku
        Yes this appears to be the problem. The link provided above is not from the repos.
        • bdobson
          • Feb 2024
          • 19
          Originally posted by cyber
          https://repo.zabbix.com/zabbix/6.4/u...main/z/zabbix/
          No... That's not right and not the place where the repos pull from...
            • 5004
            Well if metadata is wrong, then I can understand, that it is not found from that exact place.. As it does not know to look there... If you really-really want, you can download those manually and still install.
            • bdobson
              • Feb 2024
              • 19
              I understand that, don't you think Zabbix should fix their repo if it was released on the 17th and it's the 20th now?
              • Markku
                • Sep 2018
                • 1788
                Sorry to hear bdobson that you still feel you have problems. I provided you the link to the official bug report to the vendor support, so that you can follow that and expedite that with your account manager (if paying for your Zabbix support), and cyber provided you with a workaround to work with while waiting for the problem to be solved. There isn't much else we can do for you I think.
                Markku
                • bdobson
                  • Feb 2024
                  • 19
                  It's all working now, so all is well. Thank you.
