RHEL 7.3 - Cannot Disable Core Dump Exiting
  • rburkholder
    • Nov 2016
    I am receiving the following when trying to start the Zabbix agent on RHEL 7.3:
    149776:20161215:115409.918 Starting Zabbix Agent [Zabbix server]. Zabbix 3.2.2 (revision 64245).
    149776:20161215:115409.918 **** Enabled features ****
    149776:20161215:115409.918 IPv6 support:          YES
    149776:20161215:115409.918 TLS support:           YES
    149776:20161215:115409.918 **************************
    149776:20161215:115409.918 using configuration file: /etc/zabbix/zabbix_agentd.conf
    149776:20161215:115409.918 cannot set resource limit: [13] Permission denied
    149776:20161215:115409.918 cannot disable core dump, exiting...
    Using Zabbix Agent version 3.2.2. Everything I have found points to an issue with SELINUX. Is there a way to resolve this issue without disabling SELINUX?
  • DmitryL
    • May 2016
    • 278
    Try running
    > grep zabbix_agent /var/log/audit/audit.log
    If you see entries in audit log execute this command:
    > grep "denied.*zabbix_agent" /var/log/audit/audit.log | audit2allow -M zabbix_agent
    > semodule -i <module_name>.pp
    • rburkholder
      • Nov 2016
      That did the trick. Thank you!
