Hello all,
I created a map to test a state of an trigger, and when a the trigger is in problem stat, in the map, shows a problem in the element, but when I disable the trigger, the element shows as OK state in map.
In my tests, when a element is associated with a host, and the host is disabled, they assume a disabled state in the map.
Anybody can help me with the disabled triggers in the map?
