Unable to update Zabbix Agent on OpenSUSE Tumbleweed from 6.0.31 to 7.0.x
  • dbird@iqx.co.uk
    • Apr 2024
    • 9
    I have been trying unsuccessfully on a couple of VM's to update my Zabbix agent on Tumbleweed from the old working version I have (6.0.31) to a version 7 build. Whenever I try to install the newer version after updating my repos I get the following error message:
    'nothing provides 'liblber-2.4.so.2()(64bit)'
    At this point Zypper just gives me the option to not proceed or to install but with the missing dependency and possibly have a broken Zabbix agent. I did try the latter option on one of my many attempts but as expected this did not work and the Zabbix agent was not working.
    How can I get this dependency on the server to update the build? I tried installing LDAP on one of the boxes as I read that as possible solution but I do not want to make too many changes to the software installed or the configuration of the server where possible. I have this version working on OpenSUSE Leap boxes with no issues and other Linux Distros but I simply cannot get this on Tumbleweed. Is this possible or should I quit while ahead and use the 6.0.31 connecting to my 7.0.x server for now?
  • dbird@iqx.co.uk
    • Apr 2024
    • 9
    SOLVED - installed Zabbix Agent2 instead.
