More than 100 items having missing data for more than 10 minutes
  • Mechanix
    • Jan 2017
    • 92
    I´m facing a really weird situation. Here is my zabbix installation:
    DISTRIB_ID=Ubuntu
    DISTRIB_RELEASE=16.04
    DISTRIB_CODENAME=xenial
    DISTRIB_DESCRIPTION="Ubuntu 16.04.1 LTS"
    Zabbix: 3.2
    VM: 3xCPU ; 4GB RAM; 50GB HDD
    Every now and then zabbix stops creating graphs and I get a warning:
    I have checked the logs but there is nothing pointing to this issue.
    Right now I´m monitoring 2 Juniper devices!
    Device 1 Applications 4 Items 1445 Triggers 16 Graphs 244 Discovery 1
    Device2 Applications 3 Items 1650 Triggers 14 Graphs 281 Discovery 2
    Can anybody help me figure out what is happening? Right now we are evaluating zabbix but if there a such huge issues with just two hosts, we cannot proceed implementing it for 100 devices.
    Any help is appreciated. Thank you
  • batchenr
    • Sep 2016
    • 440
    DISTRIB_ID=Ubuntu
    Zabbix: 3.2
    check if you have unsupported items under this hosts
    and cancel \ fix them it can cause interuppts and SNMP connection can get lost.
    second - update zabbix_server.conf TimeOut to 30 sec and restart
    see if it helps
    • Mechanix
      • Jan 2017
      • 92
      thx for your reply. This could be a hint. I will check the templates and monitor the server for a couple of hours. I´ll get back to you.
      Rgrds,
      C.
      • Mechanix
        • Jan 2017
        • 92
        You nailed it! It was indeed some unsupported items which I overlooked. Thank you so much!
        I´ve noticed some other log entries but I´ll open another thread to keep this separated.
        Regards,
        C.
