delay on zabbix alerts
  • elias_a_h
    • Jan 2017
    Dear sirs,
    Please note that we are using Zabbix to monitoring our links. the problem is that there's a lot of delay to display the trigger alert on zabbix dashboard ex: suddenly the trigger shows an alert that has been occuring 16 hours ago. Please advise Thank you in advance
    Regards
  • batchenr
    • Sep 2016
    • 440
    Originally posted by elias_a_h
    Dear sirs,
    Regards
    first check if the item Update interval is not over 30 sec
    second - provok a trigger and see if you see its alert on zabbix log
    like this : Reports -> Action log to see if it fires an email\sms (if set to)
    is zabbix loading slowly for you ? if your opening latest data for a large host
    is it takes more then 10 sec ?
