Unable to install zabbix on Ubuntu 24.04
  • somedude
    • Sep 2024
    I've built a new Ubuntu server 24.04 LTS and followed the installation instructions.
    When I try and install the zabbix-server-mysql package I get a dependency error:
    zabbix-server-mysql : Depends: libldap-2.5-0 (>= 2.5.4) but it is not installable
    I've got libldap 2.6.7. installed:
    root@zabbix:/home/greg# dpkg -l | grep libldap
    ii libldap-common 2.6.7+dfsg-1~exp1ubuntu8 all OpenLDAP common files for libraries
    Any ideas how to solve this error?
  • somedude
    • Sep 2024
    I fixed this. Would help if I read correctly. I downloaded the Zabbix version for Ubuntu 22.04 instead of 24.04
    • tim.mooney
      • Dec 2012
      • 1435
      Are you certain you downloaded the correct package(s) from www.zabbix.com ? It seems like you may have had the wrong version of Ubuntu selected from the "what do you want" download selector.
      • hhmhomelab
        • Jun 2025
        There is a error in de download wizzard.
        If you select 7.2 => Ubuntu => 24.4 Noble => Agent
        The folow file will be download: wget https://repo.zabbix.com/zabbix/7.2/r...u22.04_all.deb
        change to:
        wget https://repo.zabbix.com/zabbix/7.2/r...u24.04_all.deb
