Zabbix 7.2 does not work with grafana
  • lphbraz
    • Dec 2024
    Hello, I installed the latest version of Zabbix (7.2) on all the company's production hosts. When trying to integrate with Grafana (latest version), after adding and enabling the plugin in its latest version, I get the following error: "Invalid request. Invalid parameter "/": unexpected parameter "auth"
    I sought help from the plugin and Grafana support, but they told me it was a Zabbix problem, that version 7.2 should not be used. (https://github.com/grafana/grafana-zabbix/issues/1914)
    So what do I do now? If version 7.2 should not be used, why is it available for download on the website? I had a lot of work installing and configuring all the Zabbix agents on all the servers.
  • ISiroshtan
    • Nov 2019
    • 324
    So people can try and test possible new features prior to release. The website clearly says it's a pre-release version, so you properly got a response from Grafana community that 7.2 Zabbix is not production version atm.
    • gfvendra
      • Dec 2024
      The problem continued with the release of the version.
      • ISiroshtan
        • Nov 2019
        • 324
        Now it's on products side to update API integration to adhere to 7.2 changes (first change in changelog)
          • 5004
          You do understand, that Grafana plugin is NOT maintained by Zabbix.... ?
        • ISiroshtan
          • Nov 2019
          • 324
          cherkana i honestly lost on your logic. The integration is designed and supported by non-affiliated to Zabbix person. Zabbix team collected information about all such integrations so people can easily find them.
          Now, the change to auth process was done in version 6.4 where they set 'auth' parameter as deprecated, but still supported it for compatibility reasons. It was on 6th of march 2023.
          With 7.2 they finally removing the deprecated param. In Dec 2024.
          So Grafana plugin maintainer had 1.5+ years to update code to support new authentication model. Which seemingly was not done.
          How come it is Zabbix side problem in your eyes?
            • 5004
            They plan a realease for tomorrow... https://github.com/grafana/grafana-zabbix/issues/1914
            If I understand it correctly, you can already download "fixed" version directly .. https://storage.googleapis.com/integ...inux_amd64.zip
            • gfvendra
              • Dec 2024
              The problem has been fixed, you need to update the plugin to version 4.6
