Zabbix Server 7.0.7 Crashing in Loop
  • studero
    • Aug 2023
    • 85
    I want to update my Zabbix server to version 7.0.7. The actual version is 7.0.6. I run on RedHat 9.5.
    After apply the last version, the zabbix server process crash in loop. Why ? How can I verify the problem ?
    3415878:20241227:094432.784 Got signal [signal:11(SIGSEGV),reason:1,refaddrnil)]. Crashing ...
    3415878:20241227:094432.784 ====== Fatal information: ======
    3415878:20241227:094432.784 Program counter: 0x7f16a9ab6051
    3415878:20241227:094432.784 === Registers: ===
    3415878:20241227:094432.784 r8 = 0 = 0 = 0
    3415878:20241227:094432.784 r9 = 7ffc958ebf37 = 140722817646391 = 140722817646391
    3415878:20241227:094432.784 r10 = 800 = 2048 = 2048
    3415878:20241227:094432.784 r11 = 20a31fffc552fa18 = 2351758613805201944 = 2351758613805201944
    3415878:20241227:094432.784 r12 = 55b043185580 = 94215528273280 = 94215528273280
    3415878:20241227:094432.784 r13 = 55b04314ee90 = 94215528050320 = 94215528050320
    3415878:20241227:094432.784 r14 = 0 = 0 = 0
    3415878:20241227:094432.784 r15 = 55b043175ba0 = 94215528209312 = 94215528209312
    3415878:20241227:094432.784 rdi = 0 = 0 = 0
    3415878:20241227:094432.784 rsi = 55b0431b8d90 = 94215528484240 = 94215528484240
    3415878:20241227:094432.784 rbp = 55b0431c3340 = 94215528526656 = 94215528526656
    3415878:20241227:094432.784 rbx = 55b0431856c0 = 94215528273600 = 94215528273600
    3415878:20241227:094432.784 rdx = 6f = 111 = 111
    3415878:20241227:094432.784 rax = 0 = 0 = 0
    3415878:20241227:094432.784 rcx = 1 = 1 = 1
    3415878:20241227:094432.784 rsp = 7ffc958ebe58 = 140722817646168 = 140722817646168
    3415878:20241227:094432.784 rip = 7f16a9ab6051 = 139735312588881 = 139735312588881
    3415878:20241227:094432.784 efl = 10297 = 66199 = 66199
    3415878:20241227:094432.784 csgsfs = 2b000000000033 = 12103423998558259 = 12103423998558259
    3415878:20241227:094432.784 err = 4 = 4 = 4
    3415878:20241227:094432.784 trapno = e = 14 = 14
    3415878:20241227:094432.784 oldmask = 0 = 0 = 0
    3415878:20241227:094432.784 cr2 = 0 = 0 = 0
    3415878:20241227:094432.784 === Backtrace: ===
    3415878:20241227:094432.786 18: /usr/sbin/zabbix_server: lld worker #1 [processed 3 LLD rules, idle 6.931489 sec during 6.980258 sec](zbx_backtrace+0x41) [0x55b0412dc7a1]
    3415878:20241227:094432.786 17: /usr/sbin/zabbix_server: lld worker #1 [processed 3 LLD rules, idle 6.931489 sec during 6.980258 sec](zbx_log_fatal_info+0x26d) [0x55b0412dcb3d]
    3415878:20241227:094432.786 16: /usr/sbin/zabbix_server: lld worker #1 [processed 3 LLD rules, idle 6.931489 sec during 6.980258 sec](+0x417d46) [0x55b0412dcd46]
    3415878:20241227:094432.786 15: /lib64/libc.so.6(+0x3e730) [0x7f16a9a3e730]
    3415878:20241227:094432.786 14: /lib64/libc.so.6(+0xb6051) [0x7f16a9ab6051]
    Now the server run again with version 7.0.6. Before the update I have create a VMWare snapshot.
    I need help.
    Regards
    Olivier
  • Answer selected by studero at 13-01-2025, 11:38.
    markfree
    • Apr 2019
    • 875
    Zabbix 7.0.8 was released today. The issue should be fixed.
    • markfree
      • Apr 2019
      • 875
      Zabbix is receiving a segmentation fault. The zabbix process may be trying to access an inaccessible memory location.
      Check the Zabbix logs to see if there are any error messages prior to the crash.
      Then check the memory integrity of the OS.
      Do you have cache values configured for your Zabbix Server instance?
      Is your OS somehow read-only?
      Red Hat can be a bit annoying at times, but if the problem persists, I would call support soon.
      • markfree
        • Apr 2019
        • 875
        It seems to be a bug that's already fixed. Version 7.0.8 should be available soon with the fix.
        • AlexeySaff
          • Aug 2021
          • 22
          7.2.1 is also crashing....
          • AlexeySaff
            • Aug 2021
            • 22
            disabling autoregistration actions - helped. Waiting for 7.2.2
            • marcos.della
              • Dec 2024
              • 9
              We've had this problem ourselves on scale. Rolled the zabbix_server back to 7.0.6 to get the system stable again. Basically avoid 7.0.7 release.
              • markfree
                • Apr 2019
                • 875
