[ZABBIX] Seamless Integration Series - Episode 4: DSE Genset
  • tiago.guimaraes
    • Apr 2024
    • 17
    Hello, Zabbix community!
    The fourth episode of the [ZABBIX] Seamless Integration Series is now available. This time, we explore how to integrate a DSE Genset (Deep Sea Electronics Generator Set Controller) into Zabbix using Modbus TCP.
    Key Highlights:
    • Monitor critical metrics like runtime, fuel level, battery status, and engine parameters.
    • Set up Modbus communication for data retrieval and configure custom triggers.
    • Build dashboards for real-time insights and enable remote control directly in Zabbix.
    Link to the full post: https://www.linkedin.com/pulse/zabbi...3%25A3es-yezgf
    This episode provides a macro-level overview to ensure your genset is always ready to maintain power continuity.
    Check it out, and let me know your tips or experiences with genset integrations.
    Stay tuned for more integrations in 2025!
  • Gilvan Motta
    • Jan 2025
    Hi tiago.guimaraes
    I tried to contact you via Linkedin, but I couldn't.
    I observed the interfaces and interactions with Zabbix and I really liked them.
    We have a DSE8620 generator, I got the mib file from the manufacturer but I'm still having trouble creating the template in Zabbix.
    Is it possible to make the template you created available or help me configure the template in Zabbix based on this mib file?
    • tiago.guimaraes
      • Apr 2024
      • 17
      Hi Gilvan Motta , I've sent you a private message, give me your feedback on you integration request.
      • Gilvan Motta
        • Jan 2025
        tiago.guimaraes Thank you very much for your help
        • nhts
          • Jan 2025
          Is there a template for the controller using SNMP?
          • mariusl
            • Aug 2024
            • 33
            Nice guide, but the way Modbus has been implemented in Zabbix calls for some awkward workarounds as most of the equipment to be monitored is typical OT that you can't install an agent on. Often such equipment is also isolated on L2, making it difficult to reach from the server directly.
            I really wish the Modbus implementation also was available directly from a proxy atleast. I have a feature request for this i hope the team sees: https://support.zabbix.com/browse/ZBXNEXT-9769.
            • nhts
              • Jan 2025
              tiago.guimaraes do you have a template you can share please
              • tiago.guimaraes
                • Apr 2024
                • 17
                Hi nhts ,
                I can provide you with a template; however, I need to know which protocol you intend to use for the Zabbix integration.
                • nhts
                  • Jan 2025
                  tiago.guimaraes thank you. Will be using SNMP
                  • tiago.guimaraes
                    • Apr 2024
                    • 17
                    nhts, I currently have only the template for Modbus integration. Would it be possible to discuss this in more detail via private messaging?
                    You can reach me on LinkedIn: https://www.linkedin.com/in/tiago-guimaraes-dev/
                    • nhts
                      • Jan 2025
                      yes no problem. Drop me a message tiago.guimaraes
                      • fabricioagliardi
                        • Jan 2025
                        • 10
                        Hi tiago.guimaraes , Could you send me the modbus template for zabbix? I am trying to monitor a DSE 0890
                        • Fantom
                          • Jul 2023
                          Hello Tiago, I recently read your article and was very impressed with the way you set everything up. I’ve been trying to integrate Zabbix with the DSE7410 MKII controller, but unfortunately, I haven’t been able to get it working properly.
                          Would you be willing to share the DSE template you used? I believe reviewing your implementation would help me identify where I might have gone wrong.
                          Thank you in advance for your time and help!
                          • gcaselli
                            • Oct 2022
                            Hi Tiago, great work!
                            I was trying to create a template to monitor the DSE7320 MKII. Could you share it?
                            Thanks!
