Zabbix Installation Issue: Infinite Refresh on "Parameters" UI Page
  • clemsk030
    • Jan 2025
    Hi everyone,
    I'm a French student working on an infrastructure project, and I'm sorry if my English isn't perfect.
    I'm trying to install Zabbix 7.2 on Ubuntu Server 24.04.1, and everything works fine until I reach the "Parameters" section during the UI installation. All the prerequisites are OK, but when I get to the Parameters section (right after entering the database connection details), the browser starts refreshing infinitely.
    If I clear all my cookies and refresh the page, the UI restarts at the first section, which is the welcome page.
    Thanks in advance!
  • kyus
    • Feb 2024
    • 211
    Hey!
    I've tried to reproduce the error but couldn't get it (installed it with apache2). The only difference that i noticed is that in the "Parameters" tab in the web interface configuration, I also had an option to choose the default theme of Zabbix, and your installation seems to be missing that.
    I've never seen this error in the installations I did, so I'm not sure on what you can do.
    I would suggest trying to install everything from scratch.
    I did a pretty basic install to test it, here's the commands executed:
    • Jirobien
      • Jan 2025
      Same problem here, have you found any solution?
      Thanks.
      • Jirobien
        • Jan 2025
        Oh i test with another computer in the same network of my Zabbix server and it's works. (I don't know why I didn't think of it before ) With the first computer i'm in another network range.
        Now that the first configuration is done I can connect with the first PC outside the network of the zabby server​.
        So it seems necessary that the setup.php configuration phase takes place in the same network.​
