SNMP traps returning "unmatched" - Zabbix 7.0.6
  • jwilling
    • Apr 2021
    Kind of out of ideas on this one... Have reviewed past threads on this topic and have verified everything that was referenced, and it still is not working.
    Background: Zabbix 7.0.6 server with a proxy group of five proxy servers. We have devices sending SNMP traps directly to the Zabbix server since the assignments
    within the proxy groups can change.
    Traps are received by the server and are being parsed (apparently) properly by the perl script and written to the trap file, but every trap event returns as "unmatched".
    Have verified that the IP addresses are properly listed in the interfaces table. Have also verified that the interface id of the reporting devices exists in the interface_snmp table.
    interfaces:
    MariaDB [zabbix]> SELECT ip FROM interface WHERE main=1 AND type=2;
    | ip |
    | 10.61.176.50 |
    interfaces_snmp:
    | 22743 | 2 | 1 | {$SNMP_COMMUNITY} | | 0 | | | 0 | 0 | | 10 |
    Digging in to the server log (with the logging level turned up) I am seeing this:
    2284:20250108:101718.392 zbx_setproctitle() title:'snmp trapper [processed data in 0.001915 sec, idle 1 sec]'
    2284:20250108:101719.392 zbx_setproctitle() title:'snmp trapper [processing data]'
    2284:20250108:101719.392 In zbx_dc_config_get_snmp_interfaceids_by_addr() addr:'10.61.176.50'
    2284:20250108:101719.392 End of zbx_dc_config_get_snmp_interfaceids_by_addr():1
    2284:20250108:101719.392 In zbx_dc_config_get_snmp_items_by_interfaceid() interfaceid:22743
    2284:20250108:101719.392 End of zbx_dc_config_get_snmp_items_by_interfaceid():0
    2284:20250108:101719.392 unmatched trap received from "10.61.176.50": 2025-01-08T10:17:17-0600 PDU INFO:
    requestid 791638964
    transactionid 2706
    messageid 0
    community xxxxxxxxx
    version 1
    notificationtype TRAP
    receivedfrom UDP: [10.61.176.50]:43339->[xxx.xxx.xxx.xxx]:162
    errorindex 0
    errorstatus 0
    VARBINDS:
    If I am reading this correctly, it looks like the "zbx_dc_config_get_snmp_items_by_interfaceid() " function is returning false,
    so the question becomes why?
    If I generate a test 'trap' directly on the server, it processes as expected. The only obvious difference is that the interfaceid function
    is returning true.
    Any thoughts?
  • Answer selected by tim.mooney at 12-01-2025, 09:52.
    cyber
    • 5004
    Proxy groups (native HA) is not usable with SNMP traps, it is first thing said under Limitations... https://www.zabbix.com/documentation...ha#limitations
    I think you read it and thought "then I will send traps to server".. Thats not how things work.. Your devices are monitored by proxies, server has no knowledge about them from monitoring duties perspective.
    Either set "no proxy" for all your devices (make server "monitor" them) and increase the load of server, or drop whole native HA, make devices send traps to a assigned proxy ... or build proxy HA with other means like corosync/pacemaker cluster
      • 5004
      • jwilling
        • Apr 2021
        In retrospect that makes sense. Though we have far too many monitored devices to completely abandon the 'proxy group' model. Not to mention the loss of redundancy.
        So I created a 'standalone' proxy outside of the group and assigned the devices that need to send SNMP traps to that unit, and things started working! A bit of a roundabout, but it gets us to where we need to be.
        Thanks for your input, it saved me a good deal of chasing about trying to figure this one out.
