Hi, I am facing the subjected error as my zabbix is not being started properly. it's continuously in stopping and starting the service. The output of zabbix_server.log is as follows. However, it's agent is working fine.
134161:20250318:101325.256 Starting Zabbix Server. Zabbix 4.4.6 (revision 8cc702429d).
134161:20250318:101325.256 ****** Enabled features ******
134161:20250318:101325.256 SNMP monitoring: YES
134161:20250318:101325.256 IPMI monitoring: YES
134161:20250318:101325.256 Web monitoring: YES
134161:20250318:101325.256 VMware monitoring: YES
134161:20250318:101325.256 SMTP authentication: YES
134161:20250318:101325.256 ODBC: YES
134161:20250318:101325.257 SSH support: YES
134161:20250318:101325.257 IPv6 support: YES
134161:20250318:101325.257 TLS support: YES
134161:20250318:101325.257 ******************************
134161:20250318:101325.257 using configuration file: /etc/zabbix/zabbix_server.conf
134161:20250318:101325.260 current database version (mandatory/optional): 04040000/04040001
134161:20250318:101325.260 required mandatory version: 04040000
134161:20250318:101325.269 server #0 started [main process]
134166:20250318:101325.270 server #1 started [configuration syncer #1]
134169:20250318:101326.472 server #2 started [housekeeper #1]
134170:20250318:101326.472 server #3 started [timer #1]
134171:20250318:101326.473 server #4 started [http poller #1]
134173:20250318:101326.473 server #5 started [discoverer #1]
134174:20250318:101326.473 server #6 started [history syncer #1]
134175:20250318:101326.473 server #7 started [history syncer #2]
134176:20250318:101326.474 server #8 started [history syncer #3]
134177:20250318:101326.474 server #9 started [history syncer #4]
134178:20250318:101326.474 server #10 started [escalator #1]
134185:20250318:101326.475 server #12 started [self-monitoring #1]
134187:20250318:101326.475 server #14 started [poller #1]
134201:20250318:101326.481 server #27 started [alerter #1]
134202:20250318:101326.481 server #28 started [alerter #2]
134188:20250318:101326.481 server #15 started [poller #2]
134186:20250318:101326.481 server #13 started [task manager #1]
134191:20250318:101326.482 server #18 started [poller #5]
134180:20250318:101326.486 server #11 started [proxy poller #1]
134189:20250318:101326.486 server #16 started [poller #3]
134200:20250318:101326.488 server #26 started [alert manager #1]
134204:20250318:101326.488 server #30 started [preprocessing manager #1]
134193:20250318:101326.488 server #19 started [unreachable poller #1]
134209:20250318:101326.491 server #35 started [lld worker #1]
134197:20250318:101326.492 server #23 started [trapper #4]
134194:20250318:101326.492 server #20 started [trapper #1]
134198:20250318:101326.494 server #24 started [trapper #5]
134211:20250318:101326.496 server #37 started [alert syncer #1]
134210:20250318:101326.496 server #36 started [lld worker #2]
134199:20250318:101326.497 server #25 started [icmp pinger #1]
134195:20250318:101326.498 server #21 started [trapper #2]
134190:20250318:101326.499 server #17 started [poller #4]
134208:20250318:101326.499 server #34 started [lld manager #1]
134203:20250318:101326.499 server #29 started [alerter #3]
134196:20250318:101326.500 server #22 started [trapper #3]
134207:20250318:101327.100 server #33 started [preprocessing worker #3]
134205:20250318:101327.182 server #31 started [preprocessing worker #1]
134206:20250318:101327.182 server #32 started [preprocessing worker #2]
134194:20250318:101327.453 cannot send list of active checks to "10.128.20.225": host [fcubsdb] not found
134203:20250318:101328.103 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x58]. Crashing ...
134203:20250318:101328.103 ====== Fatal information: ======
134203:20250318:101328.103 Program counter: 0x7f274304a1cf
134203:20250318:101328.103 === Registers: ===
134203:20250318:101328.103 r8 = 0 = 0 = 0
134203:20250318:101328.103 r9 = 7ffed200d110 = 140732421689616 = 140732421689616
134203:20250318:101328.103 r10 = 7ffed200c060 = 140732421685344 = 140732421685344
134203:20250318:101328.103 r11 = 7f274304a1b0 = 139806604829104 = 139806604829104
134203:20250318:101328.103 r12 = 7ffed200c890 = 140732421687440 = 140732421687440
134203:20250318:101328.103 r13 = 10 = 16 = 16
134203:20250318:101328.103 r14 = 10 = 16 = 16
134203:20250318:101328.103 r15 = a = 10 = 10
134203:20250318:101328.103 rdi = 0 = 0 = 0
134203:20250318:101328.103 rsi = 7ffed200c890 = 140732421687440 = 140732421687440
134203:20250318:101328.103 rbp = 10 = 16 = 16
134203:20250318:101328.104 rbx = 0 = 0 = 0
134203:20250318:101328.104 rdx = 10 = 16 = 16
134203:20250318:101328.104 rax = 0 = 0 = 0
134203:20250318:101328.104 rcx = 7f2748241300 = 139806690775808 = 139806690775808
134203:20250318:101328.104 rsp = 7ffed200c5b0 = 140732421686704 = 140732421686704
134203:20250318:101328.104 rip = 7f274304a1cf = 139806604829135 = 139806604829135
134203:20250318:101328.104 efl = 10206 = 66054 = 66054
134203:20250318:101328.104 csgsfs = 33 = 51 = 51
134203:20250318:101328.104 err = 6 = 6 = 6
134203:20250318:101328.104 trapno = e = 14 = 14
134203:20250318:101328.104 oldmask = 0 = 0 = 0
134203:20250318:101328.104 cr2 = 58 = 88 = 88
134203:20250318:101328.104 === Backtrace: ===
134203:20250318:101328.104 21: /usr/sbin/zabbix_server: alerter #3 started(zbx_backtrace+0x42) [0x55a688954024]
134203:20250318:101328.104 20: /usr/sbin/zabbix_server: alerter #3 started(zbx_log_fatal_info+0x151) [0x55a6889542a2]
134203:20250318:101328.104 19: /usr/sbin/zabbix_server: alerter #3 started(+0x1a863a) [0x55a68895463a]
134203:20250318:101328.104 18: /lib64/libpthread.so.0(+0xf630) [0x7f2748039630]
134203:20250318:101328.104 17: /lib64/libnss3.so(PK11_DigestOp+0x1f) [0x7f274304a1cf]
134203:20250318:101328.104 16: /lib64/libcurl.so.4(+0x4409a) [0x7f274594e09a]
134203:20250318:101328.104 15: /lib64/libcurl.so.4(+0x50089) [0x7f274595a089]
134203:20250318:101328.104 14: /lib64/libcurl.so.4(+0x49ed8) [0x7f2745953ed8]
134203:20250318:101328.104 13: /lib64/libcurl.so.4(+0x48c1e) [0x7f2745952c1e]
134203:20250318:101328.104 12: /lib64/libcurl.so.4(+0x33728) [0x7f274593d728]
134203:20250318:101328.104 11: /lib64/libcurl.so.4(curl_multi_perform+0xd1) [0x7f274593e641]
134203:20250318:101328.104 10: /lib64/libcurl.so.4(curl_easy_perform+0xf3) [0x7f2745935853]
134203:20250318:101328.104 9: /usr/sbin/zabbix_server: alerter #3 started(+0x1b95f0) [0x55a6889655f0]
134203:20250318:101328.104 8: /usr/sbin/zabbix_server: alerter #3 started(send_email+0x249) [0x55a688965984]
134203:20250318:101328.104 7: /usr/sbin/zabbix_server: alerter #3 started(+0x428a2) [0x55a6887ee8a2]
134203:20250318:101328.104 6: /usr/sbin/zabbix_server: alerter #3 started(alerter_thread+0x398) [0x55a6887ef0b7]
134203:20250318:101328.104 5: /usr/sbin/zabbix_server: alerter #3 started(zbx_thread_start+0x37) [0x55a688961aa7]
134203:20250318:101328.104 4: /usr/sbin/zabbix_server: alerter #3 started(MAIN_ZABBIX_ENTRY+0xb80) [0x55a6887edef7]
134203:20250318:101328.105 3: /usr/sbin/zabbix_server: alerter #3 started(daemon_start+0x305) [0x55a68895388d]
134203:20250318:101328.105 2: /usr/sbin/zabbix_server: alerter #3 started(main+0x312) [0x55a6887ed375]
134203:20250318:101328.105 1: /lib64/libc.so.6(__libc_start_main+0xf5) [0x7f2744ecc555]
134203:20250318:101328.105 0: /usr/sbin/zabbix_server: alerter #3 started(+0x40409) [0x55a6887ec409]
134203:20250318:101328.105 === Memory map: ===
134203:20250318:101328.105 55a6887ac000-55a688a9a000 r-xp 00000000 fd:00 667648 /usr/sbin/zabbix_server_mysql
134203:20250318:101328.105 55a688c99000-55a688d08000 r--p 002ed000 fd:00 667648 /usr/sbin/zabbix_server_mysql
134203:20250318:101328.105 55a688d08000-55a688d13000 rw-p 0035c000 fd:00 667648 /usr/sbin/zabbix_server_mysql
134203:20250318:101328.105 55a688d13000-55a688d1d000 rw-p 00000000 00:00 0
134203:20250318:101328.105 55a689419000-55a68943a000 rw-p 00000000 00:00 0 [heap]
134203:20250318:101328.105 55a68943a000-55a68945b000 rw-p 00000000 00:00 0 [heap]
134203:20250318:101328.105 55a68945b000-55a68947e000 rw-p 00000000 00:00 0 [heap]
134203:20250318:101328.105 7f2738000000-7f2738021000 rw-p 00000000 00:00 0
134203:20250318:101328.105 7f2738021000-7f273c000000 ---p 00000000 00:00 0
134203:20250318:101328.105 7f273ced2000-7f273ced3000 ---p 00000000 00:00 0
134203:20250318:101328.105 7f273ced3000-7f273d6d3000 rw-p 00000000 00:00 0
134203:20250318:101328.105 7f273d6d3000-7f273ded3000 rw-s 00000000 00:04 27721789 /SYSV00000000 (deleted)
134203:20250318:101328.105 7f273ded3000-7f273fed3000 rw-s 00000000 00:04 27721787 /SYSV00000000 (deleted)
134203:20250318:101328.105 7f273fed3000-7f27402d3000 rw-s 00000000 00:04 27721786 /SYSV00000000 (deleted)
134203:20250318:101328.105 7f27402d3000-7f27406d3000 rw-s 00000000 00:04 27721785 /SYSV00000000 (deleted)
134203:20250318:101328.105 7f27406d3000-7f27416d3000 rw-s 00000000 00:04 27721784 /SYSV00000000 (deleted)
134203:20250318:101328.105 7f27416d3000-7f27416df000 r-xp 00000000 fd:00 664289 /usr/lib64/libnss_files-2.17.so
134203:20250318:101328.105 7f27416df000-7f27418de000 ---p 0000c000 fd:00 664289 /usr/lib64/libnss_files-2.17.so
134203:20250318:101328.105 7f27418de000-7f27418df000 r--p 0000b000 fd:00 664289 /usr/lib64/libnss_files-2.17.so
134203:20250318:101328.105 7f27418df000-7f27418e0000 rw-p 0000c000 fd:00 664289 /usr/lib64/libnss_files-2.17.so
134203:20250318:101328.105 7f27418e0000-7f27418e6000 rw-p 00000000 00:00 0
134203:20250318:101328.105 7f27418e6000-7f27418e8000 r-xp 00000000 fd:00 656714 /usr/lib64/libfreebl3.so
134203:20250318:101328.105 7f27418e8000-7f2741ae7000 ---p 00002000 fd:00 656714 /usr/lib64/libfreebl3.so
134203:20250318:101328.105 7f2741ae7000-7f2741ae8000 r--p 00001000 fd:00 656714 /usr/lib64/libfreebl3.so
134203:20250318:101328.105 7f2741ae8000-7f2741ae9000 rw-p 00002000 fd:00 656714 /usr/lib64/libfreebl3.so
134203:20250318:101328.105 7f2741ae9000-7f2741b0d000 r-xp 00000000 fd:00 656579 /usr/lib64/libselinux.so.1
134203:20250318:101328.105 7f2741b0d000-7f2741d0c000 ---p 00024000 fd:00 656579 /usr/lib64/libselinux.so.1
134203:20250318:101328.105 7f2741d0c000-7f2741d0d000 r--p 00023000 fd:00 656579 /usr/lib64/libselinux.so.1
134203:20250318:101328.105 7f2741d0d000-7f2741d0e000 rw-p 00024000 fd:00 656579 /usr/lib64/libselinux.so.1
134203:20250318:101328.105 7f2741d0e000-7f2741d10000 rw-p 00000000 00:00 0
134203:20250318:101328.105 7f2741d10000-7f2741d17000 r-xp 00000000 fd:00 664292 /usr/lib64/librt-2.17.so
134203:20250318:101328.105 7f2741d17000-7f2741f16000 ---p 00007000 fd:00 664292 /usr/lib64/librt-2.17.so
134203:20250318:101328.105 7f2741f16000-7f2741f17000 r--p 00006000 fd:00 664292 /usr/lib64/librt-2.17.so
134203:20250318:101328.105 7f2741f17000-7f2741f18000 rw-p 00007000 fd:00 664292 /usr/lib64/librt-2.17.so
134203:20250318:101328.105 7f2741f18000-7f2741f20000 r-xp 00000000 fd:00 657079 /usr/lib64/libcrypt-2.17.so
134203:20250318:101328.105 7f2741f20000-7f274211f000 ---p 00008000 fd:00 657079 /usr/lib64/libcrypt-2.17.so
134203:20250318:101328.105 7f274211f000-7f2742120000 r--p 00007000 fd:00 657079 /usr/lib64/libcrypt-2.17.so
134203:20250318:101328.105 7f2742120000-7f2742121000 rw-p 00008000 fd:00 657079 /usr/lib64/libcrypt-2.17.so
134203:20250318:101328.105 7f2742121000-7f274214f000 rw-p 00000000 00:00 0
134203:20250318:101328.105 7f274214f000-7f2742152000 r-xp 00000000 fd:00 657440 /usr/lib64/libkeyutils.so.1.5
134203:20250318:101328.105 7f2742152000-7f2742351000 ---p 00003000 fd:00 657440 /usr/lib64/libkeyutils.so.1.5
134203:20250318:101328.105 7f2742351000-7f2742352000 r--p 00002000 fd:00 657440 /usr/lib64/libkeyutils.so.1.5
134203:20250318:101328.105 7f2742352000-7f2742353000 rw-p 00003000 fd:00 657440 /usr/lib64/libkeyutils.so.1.5
134203:20250318:101328.105 7f2742353000-7f2742361000 r-xp 00000000 fd:00 672410 /usr/lib64/libkrb5support.so.0.1
134203:20250318:101328.105 7f2742361000-7f2742561000 ---p 0000e000 fd:00 672410 /usr/lib64/libkrb5support.so.0.1
134203:20250318:101328.105 7f2742561000-7f2742562000 r--p 0000e000 fd:00 672410 /usr/lib64/libkrb5support.so.0.1
134203:20250318:101328.105 7f2742562000-7f2742563000 rw-p 0000f000 fd:00 672410 /usr/lib64/libkrb5support.so.0.1
134203:20250318:101328.105 7f2742563000-7f2742595000 r-xp 00000000 fd:00 657322 /usr/lib64/libidn.so.11.6.11
134203:20250318:101328.105 7f2742595000-7f2742794000 ---p 00032000 fd:00 657322 /usr/lib64/libidn.so.11.6.11
134203:20250318:101328.105 7f2742794000-7f2742795000 r--p 00031000 fd:00 657322 /usr/lib64/libidn.so.11.6.11
134203:20250318:101328.105 7f2742795000-7f2742796000 rw-p 00032000 fd:00 657322 /usr/lib64/libidn.so.11.6.11
134203:20250318:101328.106 7f2742796000-7f27427d0000 r-xp 00000000 fd:00 656575 /usr/lib64/libnspr4.so
134203:20250318:101328.106 7f27427d0000-7f27429d0000 ---p 0003a000 fd:00 656575 /usr/lib64/libnspr4.so
134203:20250318:101328.106 7f27429d0000-7f27429d1000 r--p 0003a000 fd:00 656575 /usr/lib64/libnspr4.so
134203:20250318:101328.106 7f27429d1000-7f27429d3000 rw-p 0003b000 fd:00 656575 /usr/lib64/libnspr4.so
134203:20250318:101328.106 7f27429d3000-7f27429d5000 rw-p 00000000 00:00 0
134203:20250318:101328.106 7f27429d5000-7f27429d9000 r-xp 00000000 fd:00 672539 /usr/lib64/libplc4.so
134203:20250318:101328.106 7f27429d9000-7f2742bd8000 ---p 00004000 fd:00 672539 /usr/lib64/libplc4.so
134203:20250318:101328.106 7f2742bd8000-7f2742bd9000 r--p 00003000 fd:00 672539 /usr/lib64/libplc4.so
134203:20250318:101328.106 7f2742bd9000-7f2742bda000 rw-p 00004000 fd:00 672539 /usr/lib64/libplc4.so
134203:20250318:101328.106 7f2742bda000-7f2742bdd000 r-xp 00000000 fd:00 672540 /usr/lib64/libplds4.so
134203:20250318:101328.106 7f2742bdd000-7f2742ddc000 ---p 00003000 fd:00 672540 /usr/lib64/libplds4.so
134203:20250318:101328.106 7f2742ddc000-7f2742ddd000 r--p 00002000 fd:00 672540 /usr/lib64/libplds4.so
134203:20250318:101328.106 7f2742ddd000-7f2742dde000 rw-p 00003000 fd:00 672540 /usr/lib64/libplds4.so
134203:20250318:101328.106 7f2742dde000-7f2742e07000 r-xp 00000000 fd:00 672541 /usr/lib64/libnssutil3.so
134203:20250318:101328.106 7f2742e07000-7f2743006000 ---p 00029000 fd:00 672541 /usr/lib64/libnssutil3.so
134203:20250318:101328.106 7f2743006000-7f274300d000 r--p 00028000 fd:00 672541 /usr/lib64/libnssutil3.so
134203:20250318:101328.106 7f274300d000-7f274300e000 rw-p 0002f000 fd:00 672541 /usr/lib64/libnssutil3.so
134203:20250318:101328.106 7f274300e000-7f274313f000 r-xp 00000000 fd:00 656561 /usr/lib64/libnss3.so
134203:20250318:101328.106 7f274313f000-7f274333f000 ---p 00131000 fd:00 656561 /usr/lib64/libnss3.so
134203:20250318:101328.106 7f274333f000-7f2743344000 r--p 00131000 fd:00 656561 /usr/lib64/libnss3.so
134203:20250318:101328.106 7f2743344000-7f2743347000 rw-p 00136000 fd:00 656561 /usr/lib64/libnss3.so
134203:20250318:101328.106 7f2743347000-7f2743348000 rw-p 00000000 00:00 0
134203:20250318:101328.106 7f2743348000-7f274336d000 r-xp 00000000 fd:00 661087 /usr/lib64/libsmime3.so
134203:20250318:101328.106 7f274336d000-7f274356c000 ---p 00025000 fd:00 661087 /usr/lib64/libsmime3.so
134203:20250318:101328.106 7f274356c000-7f274356f000 r--p 00024000 fd:00 661087 /usr/lib64/libsmime3.so
134203:20250318:101328.106 7f274356f000-7f2743570000 rw-p 00027000 fd:00 661087 /usr/lib64/libsmime3.so
134203:20250318:101328.106 7f2743570000-7f27435cf000 r-xp 00000000 fd:00 661095 /usr/lib64/libssl3.so
134203:20250318:101328.106 7f27435cf000-7f27437cf000 ---p 0005f000 fd:00 661095 /usr/lib64/libssl3.so
134203:20250318:101328.106 7f27437cf000-7f27437d3000 r--p 0005f000 fd:00 661095 /usr/lib64/libssl3.so
134203:20250318:101328.106 7f27437d3000-7f27437d4000 rw-p 00063000 fd:00 661095 /usr/lib64/libssl3.so
134203:20250318:101328.106 7f27437d4000-7f27437d5000 rw-p 00000000 00:00 0
134203:20250318:101328.106 7f27437d5000-7f27437f1000 r-xp 00000000 fd:00 658605 /usr/lib64/libsasl2.so.3.0.0
134203:20250318:101328.106 7f27437f1000-7f27439f0000 ---p 0001c000 fd:00 658605 /usr/lib64/libsasl2.so.3.0.0
134203:20250318:101328.106 7f27439f0000-7f27439f1000 r--p 0001b000 fd:00 658605 /usr/lib64/libsasl2.so.3.0.0
134203:20250318:101328.106 7f27439f1000-7f27439f2000 rw-p 0001c000 fd:00 658605 /usr/lib64/libsasl2.so.3.0.0
134203:20250318:101328.106 7f27439f2000-7f27439f9000 r-xp 00000000 fd:00 657395 /usr/lib64/libgdbm.so.4.0.0
134203:20250318:101328.106 7f27439f9000-7f2743bf9000 ---p 00007000 fd:00 657395 /usr/lib64/libgdbm.so.4.0.0
134203:20250318:101328.106 7f2743bf9000-7f2743bfa000 r--p 00007000 fd:00 657395 /usr/lib64/libgdbm.so.4.0.0
134203:20250318:101328.106 7f2743bfa000-7f2743bfb000 rw-p 00008000 fd:00 657395 /usr/lib64/libgdbm.so.4.0.0
134203:20250318:101328.106 7f2743bfb000-7f2743c03000 r-xp 00000000 fd:00 667503 /usr/lib64/libOpenIPMIutils.so.0.0.1
134203:20250318:101328.106 7f2743c03000-7f2743e03000 ---p 00008000 fd:00 667503 /usr/lib64/libOpenIPMIutils.so.0.0.1
134203:20250318:101328.106 7f2743e03000-7f2743e04000 r--p 00008000 fd:00 667503 /usr/lib64/libOpenIPMIutils.so.0.0.1
134203:20250318:101328.106 7f2743e04000-7f2743e05000 rw-p 00009000 fd:00 667503 /usr/lib64/libOpenIPMIutils.so.0.0.1
134203:20250318:101328.106 7f2743e05000-7f2743e0e000 r-xp 00000000 fd:00 657141 /usr/lib64/libltdl.so.7.3.0
134203:20250318:101328.106 7f2743e0e000-7f274400d000 ---p 00009000 fd:00 657141 /usr/lib64/libltdl.so.7.3.0
134203:20250318:101328.106 7f274400d000-7f274400e000 r--p 00008000 fd:00 657141 /usr/lib64/libltdl.so.7.3.0
134203:20250318:101328.106 7f274400e000-7f274400f000 rw-p 00009000 fd:00 657141 /usr/lib64/libltdl.so.7.3.0
134203:20250318:101328.106 7f274400f000-7f2744034000 r-xp 00000000 fd:00 656742 /usr/lib64/liblzma.so.5.2.2
134203:20250318:101328.106 7f2744034000-7f2744233000 ---p 00025000 fd:00 656742 /usr/lib64/liblzma.so.5.2.2
134203:20250318:101328.106 7f2744233000-7f2744234000 r--p 00024000 fd:00 656742 /usr/lib64/liblzma.so.5.2.2
134203:20250318:101328.106 7f2744234000-7f2744235000 rw-p 00025000 fd:00 656742 /usr/lib64/liblzma.so.5.2.2
134203:20250318:101328.106 7f2744235000-7f2744266000 r-xp 00000000 fd:00 664135 /usr/lib64/libk5crypto.so.3.1
134203:20250318:101328.106 7f2744266000-7f2744465000 ---p 00031000 fd:00 664135 /usr/lib64/libk5crypto.so.3.1
134203:20250318:101328.106 7f2744465000-7f2744467000 r--p 00030000 fd:00 664135 /usr/lib64/libk5crypto.so.3.1
134203:20250318:101328.106 7f2744467000-7f2744468000 rw-p 00032000 fd:00 664135 /usr/lib64/libk5crypto.so.3.1
134203:20250318:101328.106 7f2744468000-7f274446b000 r-xp 00000000 fd:00 657003 /usr/lib64/libcom_err.so.2.1
134203:20250318:101328.107 7f274446b000-7f274466a000 ---p 00003000 fd:00 657003 /usr/lib64/libcom_err.so.2.1
134203:20250318:101328.107 7f274466a000-7f274466b000 r--p 00002000 fd:00 657003 /usr/lib64/libcom_err.so.2.1
134203:20250318:101328.107 7f274466b000-7f274466c000 rw-p 00003000 fd:00 657003 /usr/lib64/libcom_err.so.2.1
134203:20250318:101328.107 7f274466c000-7f2744745000 r-xp 00000000 fd:00 658244 /usr/lib64/libkrb5.so.3.3
134203:20250318:101328.107 7f2744745000-7f2744944000 ---p 000d9000 fd:00 658244 /usr/lib64/libkrb5.so.3.3
134203:20250318:101328.107 7f2744944000-7f2744952000 r--p 000d8000 fd:00 658244 /usr/lib64/libkrb5.so.3.3
134203:20250318:101328.107 7f2744952000-7f2744955000 rw-p 000e6000 fd:00 658244 /usr/lib64/libkrb5.so.3.3
134203:20250318:101328.107 7f2744955000-7f274499f000 r-xp 00000000 fd:00 660326 /usr/lib64/libgssapi_krb5.so.2.2
134203:20250318:101328.107 7f274499f000-7f2744b9f000 ---p 0004a000 fd:00 660326 /usr/lib64/libgssapi_krb5.so.2.2
134203:20250318:101328.107 7f2744b9f000-7f2744ba0000 r--p 0004a000 fd:00 660326 /usr/lib64/libgssapi_krb5.so.2.2
134203:20250318:101328.107 7f2744ba0000-7f2744ba2000 rw-p 0004b000 fd:00 660326 /usr/lib64/libgssapi_krb5.so.2.2
134203:20250318:101328.107 7f2744ba2000-7f2744c8b000 r-xp 00000000 fd:00 656904 /usr/lib64/libstdc++.so.6.0.19
134203:20250318:101328.107 7f2744c8b000-7f2744e8b000 ---p 000e9000 fd:00 656904 /usr/lib64/libstdc++.so.6.0.19
134203:20250318:101328.107 7f2744e8b000-7f2744e93000 r--p 000e9000 fd:00 656904 /usr/lib64/libstdc++.so.6.0.19
134203:20250318:101328.107 7f2744e93000-7f2744e95000 rw-p 000f1000 fd:00 656904 /usr/lib64/libstdc++.so.6.0.19
134203:20250318:101328.107 7f2744e95000-7f2744eaa000 rw-p 00000000 00:00 0
134203:20250318:101328.107 7f2744eaa000-7f274506e000 r-xp 00000000 fd:00 656571 /usr/lib64/libc-2.17.so
134203:20250318:101328.107 7f274506e000-7f274526d000 ---p 001c4000 fd:00 656571 /usr/lib64/libc-2.17.so
134203:20250318:101328.107 7f274526d000-7f2745271000 r--p 001c3000 fd:00 656571 /usr/lib64/libc-2.17.so
134203:20250318:101328.107 7f2745271000-7f2745273000 rw-p 001c7000 fd:00 656571 /usr/lib64/libc-2.17.so
134203:20250318:101328.107 7f2745273000-7f2745278000 rw-p 00000000 00:00 0
134203:20250318:101328.107 7f2745278000-7f274528d000 r-xp 00000000 fd:00 672560 /usr/lib64/libgcc_s-4.8.5-20150702.so.1
134203:20250318:101328.107 7f274528d000-7f274548c000 ---p 00015000 fd:00 672560 /usr/lib64/libgcc_s-4.8.5-20150702.so.1
134203:20250318:101328.107 7f274548c000-7f274548d000 r--p 00014000 fd:00 672560 /usr/lib64/libgcc_s-4.8.5-20150702.so.1
134203:20250318:101328.107 7f274548d000-7f274548e000 rw-p 00015000 fd:00 672560 /usr/lib64/libgcc_s-4.8.5-20150702.so.1
134203:20250318:101328.107 7f274548e000-7f27454ee000 r-xp 00000000 fd:00 656719 /usr/lib64/libpcre.so.1.2.0
134203:20250318:101328.107 7f27454ee000-7f27456ee000 ---p 00060000 fd:00 656719 /usr/lib64/libpcre.so.1.2.0
134203:20250318:101328.107 7f27456ee000-7f27456ef000 r--p 00060000 fd:00 656719 /usr/lib64/libpcre.so.1.2.0
134203:20250318:101328.107 7f27456ef000-7f27456f0000 rw-p 00061000 fd:00 656719 /usr/lib64/libpcre.so.1.2.0
134203:20250318:101328.107 7f27456f0000-7f2745706000 r-xp 00000000 fd:00 664291 /usr/lib64/libresolv-2.17.so
134203:20250318:101328.107 7f2745706000-7f2745906000 ---p 00016000 fd:00 664291 /usr/lib64/libresolv-2.17.so
134203:20250318:101328.107 7f2745906000-7f2745907000 r--p 00016000 fd:00 664291 /usr/lib64/libresolv-2.17.so
134203:20250318:101328.107 7f2745907000-7f2745908000 rw-p 00017000 fd:00 664291 /usr/lib64/libresolv-2.17.so
134203:20250318:101328.107 7f2745908000-7f274590a000 rw-p 00000000 00:00 0
134203:20250318:101328.107 7f274590a000-7f2745970000 r-xp 00000000 fd:00 664195 /usr/lib64/libcurl.so.4.3.0
134203:20250318:101328.107 7f2745970000-7f2745b70000 ---p 00066000 fd:00 664195 /usr/lib64/libcurl.so.4.3.0
134203:20250318:101328.107 7f2745b70000-7f2745b72000 r--p 00066000 fd:00 664195 /usr/lib64/libcurl.so.4.3.0
134203:20250318:101328.107 7f2745b72000-7f2745b73000 rw-p 00068000 fd:00 664195 /usr/lib64/libcurl.so.4.3.0
134203:20250318:101328.107 7f2745b73000-7f2745b74000 rw-p 00000000 00:00 0
134203:20250318:101328.107 7f2745b74000-7f2745b82000 r-xp 00000000 fd:00 659054 /usr/lib64/liblber-2.4.so.2.10.7
134203:20250318:101328.107 7f2745b82000-7f2745d81000 ---p 0000e000 fd:00 659054 /usr/lib64/liblber-2.4.so.2.10.7
134203:20250318:101328.107 7f2745d81000-7f2745d82000 r--p 0000d000 fd:00 659054 /usr/lib64/liblber-2.4.so.2.10.7
134203:20250318:101328.107 7f2745d82000-7f2745d83000 rw-p 0000e000 fd:00 659054 /usr/lib64/liblber-2.4.so.2.10.7
134203:20250318:101328.107 7f2745d83000-7f2745dd5000 r-xp 00000000 fd:00 672434 /usr/lib64/libldap-2.4.so.2.10.7
134203:20250318:101328.107 7f2745dd5000-7f2745fd5000 ---p 00052000 fd:00 672434 /usr/lib64/libldap-2.4.so.2.10.7
134203:20250318:101328.107 7f2745fd5000-7f2745fd7000 r--p 00052000 fd:00 672434 /usr/lib64/libldap-2.4.so.2.10.7
134203:20250318:101328.107 7f2745fd7000-7f2745fd8000 rw-p 00054000 fd:00 672434 /usr/lib64/libldap-2.4.so.2.10.7
134203:20250318:101328.107 7f2745fd8000-7f274601e000 r-xp 00000000 fd:00 667572 /usr/lib64/libevent-2.0.so.5.1.9
134203:20250318:101328.107 7f274601e000-7f274621d000 ---p 00046000 fd:00 667572 /usr/lib64/libevent-2.0.so.5.1.9
134203:20250318:101328.108 7f274621d000-7f274621e000 r--p 00045000 fd:00 667572 /usr/lib64/libevent-2.0.so.5.1.9
134203:20250318:101328.108 7f274621e000-7f274621f000 rw-p 00046000 fd:00 667572 /usr/lib64/libevent-2.0.so.5.1.9
134203:20250318:101328.108 7f274621f000-7f2746220000 rw-p 00000000 00:00 0
134203:20250318:101328.108 7f2746220000-7f2746227000 r-xp 00000000 fd:00 667497 /usr/lib64/libOpenIPMIposix.so.0.0.1
134203:20250318:101328.108 7f2746227000-7f2746426000 ---p 00007000 fd:00 667497 /usr/lib64/libOpenIPMIposix.so.0.0.1
134203:20250318:101328.108 7f2746426000-7f2746427000 r--p 00006000 fd:00 667497 /usr/lib64/libOpenIPMIposix.so.0.0.1
134203:20250318:101328.108 7f2746427000-7f2746428000 rw-p 00007000 fd:00 667497 /usr/lib64/libOpenIPMIposix.so.0.0.1
134203:20250318:101328.108 7f2746428000-7f2746516000 r-xp 00000000 fd:00 667491 /usr/lib64/libOpenIPMI.so.0.0.5
134203:20250318:101328.108 7f2746516000-7f2746716000 ---p 000ee000 fd:00 667491 /usr/lib64/libOpenIPMI.so.0.0.5
134203:20250318:101328.108 7f2746716000-7f274672e000 r--p 000ee000 fd:00 667491 /usr/lib64/libOpenIPMI.so.0.0.5
134203:20250318:101328.108 7f274672e000-7f2746733000 rw-p 00106000 fd:00 667491 /usr/lib64/libOpenIPMI.so.0.0.5
134203:20250318:101328.108 7f2746733000-7f2746737000 rw-p 00000000 00:00 0
134203:20250318:101328.108 7f2746737000-7f2746762000 r-xp 00000000 fd:00 658887 /usr/lib64/libssh2.so.1.0.1
134203:20250318:101328.108 7f2746762000-7f2746962000 ---p 0002b000 fd:00 658887 /usr/lib64/libssh2.so.1.0.1
134203:20250318:101328.108 7f2746962000-7f2746963000 r--p 0002b000 fd:00 658887 /usr/lib64/libssh2.so.1.0.1
134203:20250318:101328.108 7f2746963000-7f2746964000 rw-p 0002c000 fd:00 658887 /usr/lib64/libssh2.so.1.0.1
134203:20250318:101328.108 7f2746964000-7f2746a2c000 r-xp 00000000 fd:00 664232 /usr/lib64/libnetsnmp.so.31.0.2
134203:20250318:101328.108 7f2746a2c000-7f2746c2c000 ---p 000c8000 fd:00 664232 /usr/lib64/libnetsnmp.so.31.0.2
134203:20250318:101328.108 7f2746c2c000-7f2746c2f000 r--p 000c8000 fd:00 664232 /usr/lib64/libnetsnmp.so.31.0.2
134203:20250318:101328.108 7f2746c2f000-7f2746c31000 rw-p 000cb000 fd:00 664232 /usr/lib64/libnetsnmp.so.31.0.2
134203:20250318:101328.108 7f2746c31000-7f2746c67000 rw-p 00000000 00:00 0
134203:20250318:101328.108 7f2746c67000-7f2746cc7000 r-xp 00000000 fd:00 667604 /usr/lib64/libodbc.so.2.0.0
134203:20250318:101328.108 7f2746cc7000-7f2746ec6000 ---p 00060000 fd:00 667604 /usr/lib64/libodbc.so.2.0.0
134203:20250318:101328.108 7f2746ec6000-7f2746ec7000 r--p 0005f000 fd:00 667604 /usr/lib64/libodbc.so.2.0.0
134203:20250318:101328.108 7f2746ec7000-7f2746ece000 rw-p 00060000 fd:00 667604 /usr/lib64/libodbc.so.2.0.0
134203:20250318:101328.108 7f2746ece000-7f2746ecf000 rw-p 00000000 00:00 0
134203:20250318:101328.108 7f2746ecf000-7f274702d000 r-xp 00000000 fd:00 656745 /usr/lib64/libxml2.so.2.9.1
134203:20250318:101328.108 7f274702d000-7f274722d000 ---p 0015e000 fd:00 656745 /usr/lib64/libxml2.so.2.9.1
134203:20250318:101328.108 7f274722d000-7f2747235000 r--p 0015e000 fd:00 656745 /usr/lib64/libxml2.so.2.9.1
134203:20250318:101328.108 7f2747235000-7f2747237000 rw-p 00166000 fd:00 656745 /usr/lib64/libxml2.so.2.9.1
134203:20250318:101328.108 7f2747237000-7f2747239000 rw-p 00000000 00:00 0
134203:20250318:101328.108 7f2747239000-7f274723b000 r-xp 00000000 fd:00 664285 /usr/lib64/libdl-2.17.so
134203:20250318:101328.108 7f274723b000-7f274743b000 ---p 00002000 fd:00 664285 /usr/lib64/libdl-2.17.so
134203:20250318:101328.108 7f274743b000-7f274743c000 r--p 00002000 fd:00 664285 /usr/lib64/libdl-2.17.so
134203:20250318:101328.108 7f274743c000-7f274743d000 rw-p 00003000 fd:00 664285 /usr/lib64/libdl-2.17.so
134203:20250318:101328.108 7f274743d000-7f2747674000 r-xp 00000000 fd:00 656535 /usr/lib64/libcrypto.so.1.0.2k
134203:20250318:101328.108 7f2747674000-7f2747873000 ---p 00237000 fd:00 656535 /usr/lib64/libcrypto.so.1.0.2k
134203:20250318:101328.108 7f2747873000-7f274788f000 r--p 00236000 fd:00 656535 /usr/lib64/libcrypto.so.1.0.2k
134203:20250318:101328.108 7f274788f000-7f274789c000 rw-p 00252000 fd:00 656535 /usr/lib64/libcrypto.so.1.0.2k
134203:20250318:101328.108 7f274789c000-7f27478a0000 rw-p 00000000 00:00 0
134203:20250318:101328.108 7f27478a0000-7f2747907000 r-xp 00000000 fd:00 656551 /usr/lib64/libssl.so.1.0.2k
134203:20250318:101328.108 7f2747907000-7f2747b07000 ---p 00067000 fd:00 656551 /usr/lib64/libssl.so.1.0.2k
134203:20250318:101328.108 7f2747b07000-7f2747b0b000 r--p 00067000 fd:00 656551 /usr/lib64/libssl.so.1.0.2k
134203:20250318:101328.108 7f2747b0b000-7f2747b12000 rw-p 0006b000 fd:00 656551 /usr/lib64/libssl.so.1.0.2k
134203:20250318:101328.108 7f2747b12000-7f2747c13000 r-xp 00000000 fd:00 664286 /usr/lib64/libm-2.17.so
134203:20250318:101328.108 7f2747c13000-7f2747e12000 ---p 00101000 fd:00 664286 /usr/lib64/libm-2.17.so
134203:20250318:101328.108 7f2747e12000-7f2747e13000 r--p 00100000 fd:00 664286 /usr/lib64/libm-2.17.so
134203:20250318:101328.109 7f2747e13000-7f2747e14000 rw-p 00101000 fd:00 664286 /usr/lib64/libm-2.17.so
134203:20250318:101328.109 7f2747e14000-7f2747e29000 r-xp 00000000 fd:00 656270 /usr/lib64/libz.so.1.2.7
134203:20250318:101328.109 7f2747e29000-7f2748028000 ---p 00015000 fd:00 656270 /usr/lib64/libz.so.1.2.7
134203:20250318:101328.109 7f2748028000-7f2748029000 r--p 00014000 fd:00 656270 /usr/lib64/libz.so.1.2.7
134203:20250318:101328.109 7f2748029000-7f274802a000 rw-p 00015000 fd:00 656270 /usr/lib64/libz.so.1.2.7
134203:20250318:101328.109 7f274802a000-7f2748041000 r-xp 00000000 fd:00 656559 /usr/lib64/libpthread-2.17.so
134203:20250318:101328.109 7f2748041000-7f2748240000 ---p 00017000 fd:00 656559 /usr/lib64/libpthread-2.17.so
134203:20250318:101328.109 7f2748240000-7f2748241000 r--p 00016000 fd:00 656559 /usr/lib64/libpthread-2.17.so
134203:20250318:101328.109 7f2748241000-7f2748242000 rw-p 00017000 fd:00 656559 /usr/lib64/libpthread-2.17.so
134203:20250318:101328.109 7f2748242000-7f2748246000 rw-p 00000000 00:00 0
134203:20250318:101328.109 7f2748246000-7f2748524000 r-xp 00000000 fd:00 658604 /usr/lib64/mysql/libmysqlclient.so.18.0.0
134203:20250318:101328.109 7f2748524000-7f2748723000 ---p 002de000 fd:00 658604 /usr/lib64/mysql/libmysqlclient.so.18.0.0
134203:20250318:101328.109 7f2748723000-7f274872c000 r--p 002dd000 fd:00 658604 /usr/lib64/mysql/libmysqlclient.so.18.0.0
134203:20250318:101328.109 7f274872c000-7f2748740000 rw-p 002e6000 fd:00 658604 /usr/lib64/mysql/libmysqlclient.so.18.0.0
134203:20250318:101328.109 7f2748740000-7f2748746000 rw-p 00000000 00:00 0
134203:20250318:101328.109 7f2748746000-7f2748768000 r-xp 00000000 fd:00 656526 /usr/lib64/ld-2.17.so
134203:20250318:101328.109 7f274893a000-7f2748953000 rw-p 00000000 00:00 0
134203:20250318:101328.109 7f2748960000-7f2748961000 rw-p 00000000 00:00 0
134203:20250318:101328.109 7f2748961000-7f2748964000 rw-s 00000000 00:04 27721788 /SYSV00000000 (deleted)
134203:20250318:101328.109 7f2748964000-7f2748965000 rw-s 00000000 00:04 27721783 /SYSV00000000 (deleted)
134203:20250318:101328.109 7f2748965000-7f2748966000 rw-p 00000000 00:00 0
134203:20250318:101328.109 7f2748966000-7f2748967000 rw-p 00000000 00:00 0
134203:20250318:101328.109 7f2748967000-7f2748968000 r--p 00021000 fd:00 656526 /usr/lib64/ld-2.17.so
134203:20250318:101328.109 7f2748968000-7f2748969000 rw-p 00022000 fd:00 656526 /usr/lib64/ld-2.17.so
134203:20250318:101328.109 7f2748969000-7f274896a000 rw-p 00000000 00:00 0
134203:20250318:101328.109 7ffed1ff1000-7ffed2012000 rw-p 00000000 00:00 0 [stack]
134203:20250318:101328.109 7ffed2107000-7ffed2109000 r-xp 00000000 00:00 0 [vdso]
134203:20250318:101328.109 ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
134203:20250318:101328.109 ================================
134203:20250318:101328.109 Please consider attaching a disassembly listing to your bug report.
134203:20250318:101328.109 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
134161:20250318:101328.110 One child process died (PID:134203,exitcode/signal:1). Exiting ...
zabbix_server [134161]: Error waiting for process with PID 134203: [10] No child processes
134161:20250318:101328.116 syncing history data...
134161:20250318:101328.153 syncing history data... 100.000000%
134161:20250318:101328.153 syncing history data done
134161:20250318:101328.153 syncing trend data...
134161:20250318:101328.172 syncing trend data done
134161:20250318:101328.172 Zabbix Server stopped. Zabbix 4.4.6 (revision 8cc702429d).
