I have created /22 subnet network discovery with systemname oid along with SNMP v3 creds (creds are same for both switches and routers).
In that subnet I have 66 aruba switches and 54 versa routers. After enabling discovery rule and actions I have discovered all 66 switches in 1hr but no router showed up.
I have verified the creds its working in snmpwalk. Also double checked on the discovery rule and actions, they are absolutely fine.
Also checked on the snmpengine ID's they are unique and constant.
Have manually congifured one router its perfectly polling all required data.
Is there any catch with the versa routers in terms of network discovery..
I have also created new rule with just one ip which is up and running fine with snmp. Even though its not discovered..
Any help??
Any help??
