Host Status - Item
  • rpinheiro
    Host Status - Item
    Hi Guys,
    I have been switched to zabbix from nagios, Zabbix is a great tool !!
    I have a little problem using it:
    I did not understand "Host Availability", my hosts are behind firewall, then I'm using active checks only.
    When I create a item like:
    Description Host Status
    Type ZABBIX agent (active)
    Key status
    Type of information Numeric (integer 64bit)
    Units
    Use multiplier Do not use Custom multiplier
    Status Monitored Disabled Not supported
    Store value As is Delta (speed per second) Delta (simple change)
    Show value throw map As is
    I get it on zabbix server log:
    008019:20070110:152309 Type of received value [ZBX_NOTSUPPORTED
    ] is not suitable for [[email protected]]
    This parameter does not exist on zabbix agent, then How I get Host Status using Active Checks only ??
    Rodrigo Pinheiro
  • dantheman
    • May 2006
    • 209
    I don't believe you will be able to do that with only active checks... anyone feel free to chime in if I'm wrong..
    but a workaround you can setup a trigger that monitors one of the active check items and using the nodata function and consider a host unreachable when there has been no data collected for X amount of time.
    http://www.zabbix.com/manual/v1.1/config_triggers.php how to setup triggers
    • rpinheiro
      Thanks for your reply,
      I will use agent.ping with nodata() function to substitute that feature,
      Regards
      Rodrigo Pinheiro
