SQL Alert 513
  • ells53022
    • Sep 2025
    SQL Alert 513
    Hello, I am getting the following alert but I cant figure out what the error code means. The databases seem to be fine and everything is functioning, but I'd like to clear the alert.
    SQL: MSSQLSERVER DB: dbname: Warning: 513
    If anyone has any ideas, I'd greatly appreciate it.
    • 5004
    Google is closed?
    You left out everything that could help us to help you... where you get it, what do you do to get it, whats your setup etc etc...
    Considering MSSQL is not a supported DB for zabbix itself, your question is about some monitoring task you do ??
