Monitor Specific VMs Only
  • jimmy.mccubbins
    • Oct 2025
    • 18
    We have the wide spread CPU Uitlization over 85% trigger that is assigned to basically all VMs, but we have some specific ones that we need to know when they are over 50%. How do I create a new trigger to alert only on these specific VMs?
    We are monitoring all of these servers through VCenter.
    This is the expression we are currently using avg(/VMware Guest/vmware.vm.cpu.usage.perf[{$VMWARE.URL},{$VMWARE.VM.UUID}],2m)>50
  • jimmy.mccubbins
    • Oct 2025
    • 18
    We attempted to create a new Host and Template but It wont let us use more than 1
    • BP_Vital
      • Feb 2016
      • 50
      if you have a global trigger for CPU utilization >85%, but need to override that value to 50, i'd say macros is the way to go.
      For example
      1. add a macro {$VMWARE.VM.CPU.WARNING} with value 85 on VM template level
      2. replace existing global trigger expression avg(/VMware Guest/vmware.vm.cpu.usage.perf[{$VMWARE.URL},{$VMWARE.VM.UUID}],2m)>85 with
      {$VMWARE.VM.CPU.WARNING}.
      Logic remains the same, you will only get rid of hardcoded number.
      3. On the "special" VM's host create macro {$VMWARE.VM.CPU.WARNING} with value 50, overriding 85 on template level.
      Now the "special" hosts will trigger on cpu > 50 instead of default 85, rest will continue to trigger on >85
