Zabbix + Jabber (Openfire) = Not working
  • technoir
    • Jul 2017
    Hello.
    We have Zabbix the latest version and Openfire server the latest version. Everything is configured.
    Settings of Openfire by default.
    Openfire server is available from server Zabbix.
    When Zabbix trying to send a notification to Jabber Zabbix gets an error
    SASL authentication failed
    Help solve the problem please! Thank you
    P.S. When we try Ejabberd server - Zabbix received the same error
  • vlan99
    • Feb 2018
    Zabbix + Jabber (Openfire) - turn off SSL
    Hello all,
    I have the same error during setting up jabber(openfire) notifications.
    In older versions of Zabbix I have seen variable responsible for using ssl auth.
    Depending if it was set to 0 or 1, ssl was used or not.
    In my case, I have installed 3.2.11 version of ZBX but in this version I cannot found this parameter. Probably there is other way to turn off ssl auth.
    Maybe someone from You had the same problem and want to share resolution?
    I would be grateful for any tips.
    Thanks in advance.
    Regards,
    Michal
