Hello! I wanna create template for some of ipmi sensors for supermicro servers, but I have some problem with getting incorrect values-sensors. For example:
ipmitool (zabbix ipmi agent)
We have 1 sensor for Power Supply and status is 0 (but really is ok and two), but for majority of servers ok is like this:
. This situation is not good for creating triggers. When I get supermicro util (below is SMCIPMITool out for problematic server) :
Model of server with problem - X8DTN -F. Is it problem in ipmitool?
I can create different triggers for different model, but It seems for me it's not a good way.
PS Status | 0x0 | discrete | 0x00ff| na | na | na | na | na | na
PS1 Status | 0x1 | discrete | 0x0100| na | na | na | na | na | na PS2 Status | 0x1 | discrete | 0x0100| na | na | na | na | na | na
[SlaveAddress = 78h] [Module 1] Item | Value ---- | ----- Status | [STATUS OK](01h) Input Voltage | 229.0 V Input Current | 0.67 A Main Output Voltage | 12.15 V Main Output Current | 9.5 A Temperature 1 | 28C/82F Temperature 2 | 33C/91F Fan 1 | 9389 RPM Main Output Power | 115 W Input Power | 141 W PMBus Revision | 0x0001 PWS Serial Number | P7211CF34LT1575 PWS Module Number | PWS-721P-1R PWS Revision | REV1.2 [SlaveAddress = 7Ah] [Module 2] Item | Value ---- | ----- Status | [STATUS OK](01h) Input Voltage | 229.5 V Input Current | 0.71 A Main Output Voltage | 12.06 V Main Output Current | 10.62 A Temperature 1 | 32C/90F Temperature 2 | 34C/93F Fan 1 | 9389 RPM Main Output Power | 128 W Input Power | 153 W PMBus Revision | 0x0001 PWS Serial Number | P7211CA13VT3299 PWS Module Number | PWS-721P-1R PWS Revision | REV1.0
