Hi my server for zabbix is on 3.0 and I wish to upgrade to 3.4. Did anyone encounter any issues what should I look out for and is there a step by step guide to upgrade zabbix install?
Upgrade zabbix from 3.0 to 3.4
Tags: None
The dashboard has been enhanced so it can be customized.
Alas the result can't be as efficient as it was....
Zabbix agents on Linux, FreeBSD, Windows, AVM-Fritz!box, DD-WRT and QNAP -
Hi limbooface,
Indeed there is a step-by-step manual for updating from packages (https://www.zabbix.com/documentation...grade_packages) or from sources (https://www.zabbix.com/documentation...lation/upgrade).
The new Dashboard allow customization and you can create something similar to the previous versions and create more than one dashboard.
Regards,
Alex!Comment
Can Zabbix be upgraded directly from 3.0.x to 3.4.x? Or should that be a 2 step process (ie. first upgrade to 3.0.x -> 3.2.x and then to 3.2.x -> 3.4.x) ?
Zabbix documentation only provides the upgrade notes for 3.0 -> 3.2 (https://www.zabbix.com/documentation...rade_notes_320) and 3.2->3.4 (https://www.zabbix.com/documentation...rade_notes_340).Comment
