bad graphs with zabbix and cisco asa
  • Coma
    • Oct 2016
    • 36
    Hi
    I am using Zabbix to monitor network trafic. But sometimes we end up with bad graphs, and wrong data, but it only happens sometimes.
    AS you can see here on this picture:
    the graphs has holes in it, and the data in the read circle is wrong, we would have around 500mbit speed there.
    I am just using the standard snmp device, and its a cisco asa box.
  • volter
    • Dec 2011
    • 85
    There are "highspeed counters" in the MIBs of faster equipment. Are you using these?
    https://www.cisco.com/c/en/us/suppor...mpcounter.html
    • Coma
      • Oct 2016
      • 36
      hey
      thanks for youre reply, i manage to get it fixed. I needed the change the counters to 64bit. I dont know why its not default? after all its only 10mbit ports that dont support this from what i understand. I changed ifOutOctets/ifInOctets to ifHCOutOctets/ifHCInOctets in the template->discovery rules->Item Prototype, and the problem stopped...
