It can't send Acknowledgement operations message after updating
  • tom8254
    • Nov 2016
    • 22
    Hi Zabbix supports,
    I'm facing that Zabbix-server hasn't sent Acknowledgement operations message after completed to upgrade Zabbix server from 3.4.1 to 3.4.2 but Trigger message and recovery message are working well.
    It had worked well before upgrading to 3.4.2 version.
    How can I track what's problem?
    I checked Zabbix-server.log but there is no any error messages.
    please give me an advise to resolve this problem.
    Zabbix server version : 3.4.2
    Using Push bullet app to send message
    current database version (mandatory/optional): 03040000/03040001
  • LenR
    • Sep 2009
    • 1011
    Did you check your zabbix server log for messages during the database upgrade?
    Some conditions and macros are gone, such as {TRIGGER.STATUS}
    • allexpetrov
      • May 2017
      • 361
      Anything in Reports -> Action log?
      Regards,
      Alex!
      • tom8254
        • Nov 2016
        • 22
        below is upgrade log for database.
        How can I check that??
        38917:20170927:133134.971 Zabbix Server stopped. Zabbix 3.4.1 (revision 71734).
        154377:20170927:133135.794 Starting Zabbix Server. Zabbix 3.4.2 (revision 72885).
        154377:20170927:133135.795 ****** Enabled features ******
        154377:20170927:133135.795 SNMP monitoring: YES
        154377:20170927:133135.795 IPMI monitoring: YES
        154377:20170927:133135.795 Web monitoring: YES
        154377:20170927:133135.795 VMware monitoring: YES
        154377:20170927:133135.795 SMTP authentication: YES
        154377:20170927:133135.795 Jabber notifications: YES
        154377:20170927:133135.795 Ez Texting notifications: YES
        154377:20170927:133135.795 ODBC: YES
        154377:20170927:133135.795 SSH2 support: YES
        154377:20170927:133135.795 IPv6 support: YES
        154377:20170927:133135.795 TLS support: YES
        154377:20170927:133135.795 ******************************
        154377:20170927:133135.795 using configuration file: /etc/zabbix/zabbix_server.conf
        154377:20170927:133135.830 current database version (mandatory/optional): 03040000/03040000
        154377:20170927:133135.830 required mandatory version: 03040000
        154377:20170927:133135.830 optional patches were found
        154377:20170927:133135.830 starting automatic database upgrade
        154377:20170927:133135.896 completed 100% of database upgrade
        154377:20170927:133135.896 database upgrade fully completed
        • tom8254
          • Nov 2016
          • 22
          Regards,
          Alex!
          There is no Acknowledged log after update completion on the Action log page.
          Acknowledged message doesn't occur anymore.
          below format is setup on Action page for Acknowledgement message.
          Subject - Acknowledged: {TRIGGER.NAME}
          Message - {USER.FULLNAME} acknowledged problem at {ACK.DATE} {ACK.TIME} with the following message:
          {ACK.MESSAGE}
          Current problem status is {EVENT.STATUS}
          • Atsushi
            • Aug 2013
            • 2028
            What is set for Operations of Acknowledgment operations?
            Send message?
            Remote command?
            Notify all involved?
            • tom8254
              • Nov 2016
              • 22
              Send message?
              Remote command?
              Configuration is as below for those.
              -Operations of Acknowledgment operations-
              {ACK.MESSAGE}
              -Send messages-
              Using pushbullet script (It works for Problem and Recovery message
              -Remote command-
              No I did't setup
              -Notify all involved?-
              No I allow to receive message to only master admin.(Problem and Recovery message can receive only Acknowledge message can't receive after updating to 3.4.2 version)
              • Atsushi
                • Aug 2013
                • 2028
                I was able to send mail in the previous version, but once I checked again I could not send it.
                I will check if it is registered as a issue on 3.4.2.
                • Atsushi
                  • Aug 2013
                  • 2028
                  After checking the source, it seems that there is a change not to send to the same person who filled in the ack message in 3.4.2.
                  Please fill in ack message with a person different from the destination of the action.
                  • allexpetrov
                    • May 2017
                    • 361
                    Just have checked and yes, if you Acknowledged the issue then you don't receive an Acknowledgment message and it seems kind a logical thing. You don't need to receive an Ack message since you are the one who is acking. Don't think that this is a bug
                    Regards,
                    Alex!
                    • tom8254
                      • Nov 2016
                      • 22
                      Ah ~! I got it the change hahaha
                      It seems to be more intelligent
                      Thanks for your help~!!
                      • tom8254
                        • Nov 2016
                        • 22
                        Regards,
                        Alex!
                        Hahaha It’s my fault that i didnt check more the update explanations of 3.4.2.
                        Thank you for your help
