server process not starting 1.1.4
  • bbrendon
    • Sep 2005
    • 873
    I accidentally did a mysql restart and now zabbix server won't start.
    020364:20070204:231347 Starting zabbix_server. ZABBIX 1.1.4.
    020364:20070204:231347 Executing query:select refresh_unsupported from config
    020364:20070204:231347 Query::select refresh_unsupported from config
    020364:20070204:231347 Query failed:Incorrect information in file: './zabbix/config.frm' [1033]
    I'm currently looking for a resolution.
    Unofficial Zabbix Expert
    Blog, Corporate Site
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It seems your database is corrupted.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • bbrendon
      • Sep 2005
      • 873
      Resolved.
      I changed my.cnf
      innodb_log_file_size = 64M
      Which is apparently a no-no.
      • mrfree
        • Mar 2007
        I've just (fresh) installed zabbix 1.1.6 and got the same error.
        Your solution doesn't work to me
        Any ideas?
        Edit: I tried to open zabbix db using phpmyadmin and for every table I got the same error
        #1033 - Incorrect information in file: './zabbix/<the_table>.frm'
        • mrfree
          • Mar 2007
          I solved the problem dropping the db and re-installing schema.sql and data.sql
