Vmware monitoring Performance counter is not available
  • s.halin
    • Jan 2018
    Hello all,
    I have got trouble monitoring my vmware virtuals machines. The item about disk management are in "not supported" state because "Performance counter is not available"
    Here is the related key:
    vmware.vm.vfs.dev.write[{$URL},{HOST.HOST},scsi0:0,ops]
    Could anybody help me?
    Thanks in advance
  • troffasky
    • Jul 2008
    • 640
    I have this also. Datastores are all discovered, read/write latency items are created and work, but datastore size and utilisation items all become Not Supported.
    VMware ESXi 6.5.0 build-8294253
    Zabbix 3.4
    This is just three ESXi servers monitored through one specific proxy. All others work fine. If I change one host to not use the proxy, it immediately starts working. Proxy has 4 collectors which according to 'top' spend most of their time idle, so I assume that means I have enough of them.
    • troffasky
      • Jul 2008
      • 640
      This is logged:
       15624:20180913:112035.588 cannot get refresh rate for Datastore "5af1d70c-ca86142b-8a9b-2c44fd88545c": A specified parameter was not correct: entity
       15624:20180913:112035.590 cannot get refresh rate for Datastore "5af44ce8-0b24cb44-b25b-2c44fd88545c": A specified parameter was not correct: entity
       15624:20180913:112035.591 cannot get refresh rate for Datastore "52fb067d-a6f16913-b0d6-2c44fd8854bc": A specified parameter was not correct: entity
       15624:20180913:112035.592 cannot get refresh rate for Datastore "5af1d624-b873010e-2a39-2c44fd88545c": A specified parameter was not correct: entity
       15624:20180913:112035.594 cannot get refresh rate for Datastore "5af1d672-27dbe732-5879-2c44fd88545c": A specified parameter was not correct: entity
      • troffasky
        • Jul 2008
        • 640
        OK, it's a bug, I will upgrade to 3.4.12.
