Zabbix database down.
  • zabbixfk
    • Jun 2013
    • 256
    How do i check why i am getting 'zabbix database down' emails? I can locate the settings under 'Administration->General-Others' - but quite not able to figure out the reason.
    My Zabbix log files are huge , close to 250Mb +, and rotates every 15mins, and having difficulties in doing tail to figure out ( yes debuglevel is 4 - and i have about 100G left in /var/lib/mysql so no disk issue, ram about 20G free including swap/buffer, io seems fine, cpu is <30% used ). I did run grep for
     'database down', 'server gone away', 'not reachable'
    - but queries didn't return results for grep from the logs.
    Zabbix - 3.0.13, mysql 5.5.57
    At what condition this database down email comes ? What is the exact term to be looked at logs for this?
    Any pointers are greatly helpful.
  • zabbixfk
    • Jun 2013
    • 256
    *bump*
    Can some one reply please? I am getting emails every 15mins, and queite not able to figure out what's wrong.
    • zabbixfk
      • Jun 2013
      • 256
      Zabbix database is down
      *bump*
      Can some one reply please? I am getting emails every 15mins, and quite not able to figure out what's wrong.
      • vesper1978
        • Nov 2016
        • 59
        Have you looked at the mysql logs? Those should point you in the right direction as to why the database is down.
        • zabbixfk
          • Jun 2013
          • 256
          zabbix database is down
          Thanks for the reply.
          I did look at the logs, i don't see any errors pointing down to zabbix or database. It seems normal. MySQL db started normally (when the upgrade was done - about a month+ back)
          [root@zabbix ~]# tailf /var/log/mysqld.log
          InnoDB: Restoring possible half-written data pages from the doublewrite
          InnoDB: buffer...
          171222  8:33:13  InnoDB: Waiting for the background threads to start
          171222  8:33:14 InnoDB: 5.5.57 started; log sequence number XXXXXXXX
          171222  8:33:14 [Note] Server hostname (bind-address): '0.0.0.0'; port: XXXX
          171222  8:33:14 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
          171222  8:33:14 [Note] Server socket created on IP: '0.0.0.0'.
          171222  8:33:14 [Note] Event Scheduler: Loaded 0 events
          171222  8:33:14 [Note] /usr/libexec/mysqld: ready for connections.
          Version: '5.5.57'  socket: '/var/lib/mysql/mysql.sock'  port: XXXX  MySQL Community Server (GPL)
          ^C
          [root@zabbix ~]#
          • vesper1978
            • Nov 2016
            • 59
            Are you able to connect to the MySQL server from the cli using the user+pass for the zabbix server? If so, are you able to query any of the tables in the zabbix database itself?
            • zabbixfk
              • Jun 2013
              • 256
              zabbix database is down.
              Ofcourse yes. Without this, my zabbix server won't run. What i mean to say is zabbix server is runnig fine, i don't see any load as explained in first post, but every 15mins i am getting this email.
              How do i figure out why this email is coming?
              Where do i see actually this particular logs?
              • vesper1978
                • Nov 2016
                • 59
                You'd likely need to increase the DebugLevel in your zabbix_server.conf to 4, and then restart the zabbix-server service to get more information out of the zabbix_server.log.
                • zabbixfk
                  • Jun 2013
                  • 256
                  Its already 4. And i don't see any logs pertaining to 'Database down' or 'Database not reachable' or 'server gone away' -
                  My log files per 15 min are >250Mb and its possible to post entire log here.
                  - this was clearly mentioned in first post.
                  The question was more of -
                  why would this error comes?
                  How do i figure out or locate from where this error originated?
                  What's the location of the file which is pointing out this error?
                  There's no mention on manuals why this error comes?
                  I don't see any events or trigger or action to send email to this particular stuff - where's this configured? - I know theres's a place under Administrator->general->others which says whom all to send email in case of database gone down - but now queitly why db is going down.
                  Does Zabbix team looks these forums or this is just community driven? - the main reason is , i had also posted about issues with external scripts broken in my case after upgrade in another thread and it remains same even after 4-5 days. I know enterprise support stuff and all, but in case if basic things doesn't work i don't know how to proceed with this software.
                  Thanks.
                  • vesper1978
                    • Nov 2016
                    • 59
                    Those zabbix emails saying "database is down" are caused when the zabbix server cannot connect to the database. There can be a great many reasons as to why. Most are related to MySQL and not to Zabbix itself.
                    Your best bet is to search the zabbix_server.log for mysql/MySQL.
                    I'd suggest looking at optimizing MySQL. You may be maxing out connections at time, or queries may be timing out.
                    Here's a good guide on getting more performance out of MySQL for Zabbix.
                    https://www.percona.com/blog/2014/11...-mysql-zabbix/
                    The Zabbix team does look at these forums, however it is mostly community driven. If you're looking for quick technical support from the Zabbix team, you'll need to purchase a support package: https://www.zabbix.com/support
                    • zabbixfk
                      • Jun 2013
                      • 256
                      I coudn't get anything out of the logs though debug level is 4, other than mysqldatabase polling parameters.
                       35895:20180210:090511.163 In substitute_key_macros() data:'mysqld_cpu.pc'
                       35895:20180210:090511.163 End of substitute_key_macros():SUCCEED data:'mysqld_cpu.pc'
                       35895:20180210:090511.163 In get_value() key:'mysqld_cpu.pc'
                       35895:20180210:090511.163 In get_value_agent() host:'Zabbix server' addr:'127.0.0.1' key:'mysqld_cpu.pc' conn:'unencrypted'
                       35895:20180210:090511.163 Sending [mysqld_cpu.pc
                       36001:20180210:090528.432 In substitute_key_macros() data:'mysql.ping'
                       36001:20180210:090528.432 End of substitute_key_macros():SUCCEED data:'mysql.ping'
                       36001:20180210:090528.432 In get_value() key:'mysql.ping'
                       36001:20180210:090528.432 In get_value_agent() host:'Zabbix server' addr:'127.0.0.1' key:'mysql.ping' conn:'unencrypted'
                       36001:20180210:090528.432 Sending [mysql.ping
                       36271:20180210:090528.440 In evaluate_function() function:'Zabbix server:mysql.ping.last(0)'
                       35867:20180210:090529.066 In substitute_key_macros() data:'mysql.status[Bytes_received]'
                       35867:20180210:090529.066 End of substitute_key_macros():SUCCEED data:'mysql.status[Bytes_received]'
                       35867:20180210:090529.066 In get_value() key:'mysql.status[Bytes_received]'
                       35867:20180210:090529.066 In get_value_agent() host:'Zabbix server' addr:'127.0.0.1' key:'mysql.status[Bytes_received]' conn:'unencrypted'
                       35867:20180210:090529.066 Sending [mysql.status[Bytes_received]
                       35862:20180210:090530.532 In substitute_key_macros() data:'mysql.status[Bytes_sent]'
                       35862:20180210:090530.532 End of substitute_key_macros():SUCCEED data:'mysql.status[Bytes_sent]'
                       35862:20180210:090530.532 In get_value() key:'mysql.status[Bytes_sent]'
                       35862:20180210:090530.532 In get_value_agent() host:'Zabbix server' addr:'127.0.0.1' key:'mysql.status[Bytes_sent]' conn:'unencrypted'
                       35862:20180210:090530.532 Sending [mysql.status[Bytes_sent]
                       36263:20180210:090531.010 In evaluate_function() function:'genie-mysql-1:agent.ping.nodata(10m)'
                       35948:20180210:090531.567 In substitute_key_macros() data:'mysql.status[Com_begin]'
                       35948:20180210:090531.567 End of substitute_key_macros():SUCCEED data:'mysql.status[Com_begin]'
                       35948:20180210:090531.567 In get_value() key:'mysql.status[Com_begin]'
                       35948:20180210:090531.567 In get_value_agent() host:'Zabbix server' addr:'127.0.0.1' key:'mysql.status[Com_begin]' conn:'unencrypted'
                       35948:20180210:090531.567 Sending [mysql.status[Com_begin]
                       36025:20180210:090532.596 In substitute_key_macros() data:'mysql.status[Com_commit]'
                       36025:20180210:090532.596 End of substitute_key_macros():SUCCEED data:'mysql.status[Com_commit]'
                       36025:20180210:090532.596 In get_value() key:'mysql.status[Com_commit]'
                       36025:20180210:090532.596 In get_value_agent() host:'Zabbix server' addr:'127.0.0.1' key:'mysql.status[Com_commit]' conn:'unencrypted'
                       36025:20180210:090532.596 Sending [mysql.status[Com_commit]
                       36014:20180210:090533.646 In substitute_key_macros() data:'mysql.status[Com_delete]'
                       36014:20180210:090533.646 End of substitute_key_macros():SUCCEED data:'mysql.status[Com_delete]'
                       36014:20180210:090533.646 In get_value() key:'mysql.status[Com_delete]'
                       36014:20180210:090533.646 In get_value_agent() host:'Zabbix server' addr:'127.0.0.1' key:'mysql.status[Com_delete]' conn:'unencrypted'
                       36014:20180210:090533.646 Sending [mysql.status[Com_delete]
                       35867:20180210:090534.661 In substitute_key_macros() data:'mysql.status[Com_insert]'
                       35867:20180210:090534.661 End of substitute_key_macros():SUCCEED data:'mysql.status[Com_insert]'
                       35867:20180210:090534.661 In get_value() key:'mysql.status[Com_insert]'
                       35867:20180210:090534.661 In get_value_agent() host:'Zabbix server' addr:'127.0.0.1' key:'mysql.status[Com_insert]' conn:'unencrypted'
                       35867:20180210:090534.661 Sending [mysql.status[Com_insert]
                       36018:20180210:090535.677 In substitute_key_macros() data:'mysql.status[Com_rollback]'
                       36018:20180210:090535.677 End of substitute_key_macros():SUCCEED data:'mysql.status[Com_rollback]'
                       36018:20180210:090535.677 In get_value() key:'mysql.status[Com_rollback]'
                       36018:20180210:090535.677 In get_value_agent() host:'Zabbix server' addr:'127.0.0.1' key:'mysql.status[Com_rollback]' conn:'unencrypted'
                       36018:20180210:090535.677 Sending [mysql.status[Com_rollback]
                       36018:20180210:090536.698 In substitute_key_macros() data:'mysql.status[Com_select]'
                       36018:20180210:090536.698 End of substitute_key_macros():SUCCEED data:'mysql.status[Com_select]'
                       36018:20180210:090536.698 In get_value() key:'mysql.status[Com_select]'
                       36018:20180210:090536.698 In get_value_agent() host:'Zabbix server' addr:'127.0.0.1' key:'mysql.status[Com_select]' conn:'unencrypted'
                       36018:20180210:090536.698 Sending [mysql.status[Com_select]
                       35850:20180210:090537.385 In substitute_key_macros() data:'mysql.status[Com_update]'
                       35850:20180210:090537.385 End of substitute_key_macros():SUCCEED data:'mysql.status[Com_update]'
                       35850:20180210:090537.385 In get_value() key:'mysql.status[Com_update]'
                       35850:20180210:090537.385 In get_value_agent() host:'Zabbix server' addr:'127.0.0.1' key:'mysql.status[Com_update]' conn:'unencrypted'
                       35850:20180210:090537.385 Sending [mysql.status[Com_update]
                       36020:20180210:090538.753 In substitute_key_macros() data:'mysql.status[Questions]'
                       36020:20180210:090538.753 End of substitute_key_macros():SUCCEED data:'mysql.status[Questions]'
                      Processlist from mysql shows only ~355 connections, not maxing out at any time.
                      [root@zabbix ~]# mysql -uroot -p --skip-column-names -e 'SHOW PROCESSLIST;' | wc -ll
                      Enter password:
                      347
                      [root@zabbix ~]#
                      pstree shows this output. Looks like from /etc/my.cnf its taking max_connextions and setting to 450.
                      [root@zabbix ~]# pstree
                      init─┬─abrtd
                           ├─acpid
                           ├─atd
                           ├─auditd───{auditd}
                           ├─automount───4*[{automount}]
                           ├─certmonger
                           ├─console-kit-dae───63*[{console-kit-da}]
                           ├─crond───crond─┬─logrotate───bzip2
                           │               └─sendmail───postdrop
                           ├─cupsd
                           ├─dbus-daemon
                           ├─hald─┬─hald-runner─┬─hald-addon-acpi
                           │      │             └─hald-addon-inpu
                           │      └─{hald}
                           ├─httpd───17*[httpd]
                           ├─irqbalance
                           ├─login───bash
                           ├─master─┬─pickup
                           │        └─qmgr
                           ├─mcelog
                           ├─5*[mingetty]
                           ├─mysqld_safe───mysqld───451*[{mysqld}]
                           ├─ntpd
                           ├─rpc.statd
                           ├─rpcbind
                           ├─rsyslogd───3*[{rsyslogd}]
                           ├─snmpd
                           ├─sshd─┬─3*[sshd───sshd───bash]
                           │      └─sshd───bash───pstree
                           ├─udevd───2*[udevd]
                           ├─zabbix_agentd───5*[zabbix_agentd]
                           └─zabbix_server─┬─418*[zabbix_server]
                                           └─30*[zabbix_server───sh───fping]
                      [root@zabbix ~]#
                      Some gotcha issues which i am not able to figure out from any points.
                      Let me look at perkona presentation.
                      Oh Finally, so i also need to look at support package. Thanks for that.
                      Strange issue is, though i set Group for database down message to None, i am still getting zabbix down emails
                      • Arpishke
                        • Apr 2018
                        Guys, check the server SPACE, for me i ran out of space and that was the reason for this error. try to ssh to the Zabbix server and do: df -h and for me was Used 100%
                        • tienpt
                          • Sep 2012
                          • 29
                          Today I ground this issue again. The cause is OutOfMemory which declares in /var/log/syslog.
                          I also question: where is the trigger: "Zabbix database is down." when receiving an email from Zabbix. Then I could not find that in Configuration/ Hosts/ Triggers.
                          After that, I still receive another email with the same subject. Then I check the status of mysql service, and find mysql has restarted. Go /var/log/syslog, I find "OutOfMemory", so mysql service have been killed. Hope this help.
                          Also why this email "Zabbix database is down" doesn't show in Report/ Action Log? Because the database was down, so it could not write this "Zabbix database is down" to MySQL, then show it in Zabbix Portal.
                          • Osdansua
                            • Jan 2021
                            Please, I need help. My Zabbix server is down:
                            ● zabbix-server.service - Zabbix Server
                            Loaded: loaded (/usr/lib/systemd/system/zabbix-server.service; enabled; vendor preset: disabled)
                            Active: deactivating (stop-sigterm) since Sat 2021-01-02 21:42:07 -05; 22min ago
                            Process: 938971 ExecStop=/bin/kill -SIGTERM $MAINPID (code=exited, status=0/SUCCESS)
                            Process: 569486 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
                            Main PID: 569489 (zabbix_server)
                            Tasks: 70 (limit: 49053)
                            Memory: 721.0M
                            CGroup: /system.slice/zabbix-server.service
                            ├─569489 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
                            ├─569497 /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.088416 sec, syncing configuration]
                            ├─569500 /usr/sbin/zabbix_server: housekeeper [connecting to the database]
                            ├─569501 /usr/sbin/zabbix_server: timer #1 [updated 0 hosts, suppressed 0 events in 0.000393 sec, processing maintenances]
                            ├─569502 /usr/sbin/zabbix_server: http poller #1 [got 0 values in 0.000600 sec, getting values]
                            ├─569503 /usr/sbin/zabbix_server: discoverer #1 [processed 0 rules in 0.000650 sec, performing discovery]
                            ├─569504 /usr/sbin/zabbix_server: discoverer #2 [processed 0 rules in 0.000683 sec, performing discovery]
                            ├─569506 /usr/sbin/zabbix_server: discoverer #3 [processed 0 rules in 0.000477 sec, performing discovery]
                            ├─569508 /usr/sbin/zabbix_server: discoverer #4 [processed 0 rules in 0.000637 sec, performing discovery]
                            ├─569509 /usr/sbin/zabbix_server: discoverer #5 [processed 0 rules in 0.000666 sec, performing discovery]
                            ├─569510 /usr/sbin/zabbix_server: history syncer #1 [processed 11 values, 18 triggers in 0.001515 sec, syncing history]
                            ├─569512 /usr/sbin/zabbix_server: history syncer #2 [processed 0 values, 0 triggers in 0.000113 sec, syncing history]
                            ├─569513 /usr/sbin/zabbix_server: history syncer #3 [processed 0 values, 0 triggers in 0.009424 sec, syncing history]
                            ├─569514 /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000033 sec, syncing history]
                            ├─569515 /usr/sbin/zabbix_server: escalator #1 [processed 0 escalations in 0.000816 sec, processing escalations]
                            ├─569516 /usr/sbin/zabbix_server: proxy poller #1 [terminated]
                            ├─569518 /usr/sbin/zabbix_server: self-monitoring #1 [terminated]
                            ├─569519 /usr/sbin/zabbix_server: task manager [processing tasks]
                            ├─569520 /usr/sbin/zabbix_server: poller #1 [got 4 values in 12.007649 sec, getting values]
                            ├─569522 /usr/sbin/zabbix_server: poller #2 [got 68 values in 5.081793 sec, getting values]
                            ├─569523 /usr/sbin/zabbix_server: poller #3 [got 4 values in 12.007478 sec, getting values]
                            ├─569524 /usr/sbin/zabbix_server: poller #4 [got 75 values in 15.204384 sec, getting values]
                            ├─569525 /usr/sbin/zabbix_server: poller #5 [got 76 values in 14.802647 sec, getting values]
                            ├─569526 /usr/sbin/zabbix_server: poller #6 [got 63 values in 3.690285 sec, getting values]
                            ├─569527 /usr/sbin/zabbix_server: poller #7 [got 126 values in 5.755994 sec, getting values]
                            ├─569528 /usr/sbin/zabbix_server: poller #8 [got 230 values in 5.326867 sec, getting values]
                            ├─569529 /usr/sbin/zabbix_server: poller #9 [got 219 values in 5.853566 sec, getting values]
                            ├─569530 /usr/sbin/zabbix_server: poller #10 [got 4 values in 12.007095 sec, getting values]
                            ├─569531 /usr/sbin/zabbix_server: poller #11 [got 4 values in 12.012434 sec, getting values]
                            ├─569532 /usr/sbin/zabbix_server: poller #12 [got 68 values in 13.774684 sec, getting values]
                            ├─569533 /usr/sbin/zabbix_server: poller #13 [got 64 values in 4.577797 sec, getting values]
                            ├─569534 /usr/sbin/zabbix_server: poller #14 [got 348 values in 4.523472 sec, getting values]
                            ├─569536 /usr/sbin/zabbix_server: poller #15 [got 4 values in 12.008245 sec, getting values]
                            ├─569537 /usr/sbin/zabbix_server: poller #16 [got 86 values in 6.010990 sec, getting values]
                            ├─569538 /usr/sbin/zabbix_server: poller #17 [got 639 values in 4.721309 sec, getting values]
                            ├─569539 /usr/sbin/zabbix_server: poller #18 [got 4 values in 12.009918 sec, getting values]
                            ├─569540 /usr/sbin/zabbix_server: poller #19 [got 4 values in 12.011971 sec, getting values]
                            ├─569541 /usr/sbin/zabbix_server: poller #20 [got 147 values in 14.441408 sec, getting values]
                            ├─569542 /usr/sbin/zabbix_server: unreachable poller #1 [got 0 values in 0.000137 sec, getting values]
                            ├─569543 /usr/sbin/zabbix_server: unreachable poller #2 [got 5 values in 2.763210 sec, getting values]
                            ├─569544 /usr/sbin/zabbix_server: unreachable poller #3 [got 0 values in 0.000103 sec, getting values]
                            ├─569546 /usr/sbin/zabbix_server: unreachable poller #4 [got 0 values in 0.000021 sec, getting values]
                            ├─569547 /usr/sbin/zabbix_server: unreachable poller #5 [got 0 values in 0.000100 sec, getting values]
                            ├─569549 /usr/sbin/zabbix_server: unreachable poller #6 [got 0 values in 0.000076 sec, getting values]
                            ├─569550 /usr/sbin/zabbix_server: unreachable poller #7 [got 0 values in 0.000236 sec, getting values]
                            ├─569551 /usr/sbin/zabbix_server: unreachable poller #8 [got 0 values in 0.000024 sec, getting values]
                            ├─569552 /usr/sbin/zabbix_server: unreachable poller #9 [got 0 values in 0.000031 sec, getting values]
                            ├─569553 /usr/sbin/zabbix_server: unreachable poller #10 [got 0 values in 0.000032 sec, getting values]
                            ├─569554 /usr/sbin/zabbix_server: trapper #1 [terminated]
                            ├─569555 /usr/sbin/zabbix_server: trapper #2 [processing data]
                            ├─569556 /usr/sbin/zabbix_server: trapper #3 [processing data]
                            ├─569557 /usr/sbin/zabbix_server: trapper #4 [processing data]
                            ├─569559 /usr/sbin/zabbix_server: trapper #5 [processing data]
                            ├─569560 /usr/sbin/zabbix_server: icmp pinger #1 [pinging hosts]
                            ├─569561 /usr/sbin/zabbix_server: icmp pinger #2 [pinging hosts]
                            ├─569562 /usr/sbin/zabbix_server: icmp pinger #3 [pinging hosts]
                            ├─569563 /usr/sbin/zabbix_server: icmp pinger #4 [pinging hosts]
                            ├─569564 /usr/sbin/zabbix_server: icmp pinger #5 [pinging hosts]
                            ├─569565 /usr/sbin/zabbix_server: alert manager #1 [terminated]
                            ├─569566 /usr/sbin/zabbix_server: alerter #1 [sent 0, failed 0 alerts, idle 899.947355 sec during 899.949409 sec]
                            ├─569567 /usr/sbin/zabbix_server: alerter #2 [sent 0, failed 0 alerts, idle 899.008745 sec during 899.010000 sec]
                            ├─569568 /usr/sbin/zabbix_server: alerter #3 [sent 0, failed 0 alerts, idle 898.946624 sec during 899.011286 sec]
                            ├─569569 /usr/sbin/zabbix_server: preprocessing manager #1 [queued 0, processed 15 values, idle 5.001800 sec during 5.001905 sec]
                            ├─569570 /usr/sbin/zabbix_server: preprocessing worker #1 started
                            ├─569571 /usr/sbin/zabbix_server: preprocessing worker #2 started
                            ├─569573 /usr/sbin/zabbix_server: preprocessing worker #3 started
                            ├─569574 /usr/sbin/zabbix_server: lld manager #1 [terminated]
                            ├─569575 /usr/sbin/zabbix_server: lld worker #1 [processed 3 LLD rules, idle 5.144417 sec during 5.193607 sec]
                            ├─569576 /usr/sbin/zabbix_server: lld worker #2 [processed 3 LLD rules, idle 7.123376 sec during 7.210671 sec]
                            └─569577 /usr/sbin/zabbix_server: alert syncer [queuing alerts]
                            dic 31 10:29:43 localhost.localdomain systemd[1]: Starting Zabbix Server...
                            dic 31 10:29:43 localhost.localdomain zabbix_server[569486]: /usr/sbin/zabbix_server: /usr/pgsql-12/lib/libpq.so.5: no version information available (required by /usr/>
                            dic 31 10:29:43 localhost.localdomain systemd[1]: zabbix-server.service: Supervising process 569489 which is not our child. We'll most likely not notice when it exits.
                            dic 31 10:29:43 localhost.localdomain systemd[1]: Started Zabbix Server.
                            ene 02 21:42:07 localhost.localdomain systemd[1]: Stopping Zabbix Server...
