housekeeping not worked at IBM DB2 database
  • linuxer
    • Feb 2015
    hello
    we have some problem in housekeeping process in my zabbix server .
    my zabbix server version is 3.0.7 and worked with IBM_DB2 database.
    my zabbix server housekeeping configuration is :
    ### Option: HousekeepingFrequency
    # How often Zabbix will perform housekeeping procedure (in hours).
    # Housekeeping is removing outdated information from the database.
    # To prevent Housekeeper from being overloaded, no more than 4 times HousekeepingFrequency
    # hours of outdated information are deleted in one housekeeping cycle, for each item.
    # To lower load on server startup housekeeping is postponed for 30 minutes after server start.
    # With HousekeepingFrequency=0 the housekeeper can be only executed using the runtime control option.
    # In this case the period of outdated information deleted in one housekeeping cycle is 4 times the
    # period since the last housekeeping cycle, but not less than 4 hours and not greater than 4 days.
    # Mandatory: no
    # Range: 0-24
    # Default:
    HousekeepingFrequency=3
    ### Option: MaxHousekeeperDelete
    # The table "housekeeper" contains "tasks" for housekeeping procedure in the format:
    # [housekeeperid], [tablename], [field], [value].
    # No more than 'MaxHousekeeperDelete' rows (corresponding to [tablename], [field], [value])
    # will be deleted per one task in one housekeeping cycle.
    # SQLite3 does not use this parameter, deletes all corresponding rows without a limit.
    # If set to 0 then no limit is used at all. In this case you must know what you are doing!
    # Mandatory: no
    # Range: 0-1000000
    # Default:
    MaxHousekeeperDelete=5000
    in bellow you can see housekeeping log at debug level 2
    1177650:20180228:123520.427 executing housekeeper
    1177650:20180228:123520.633 housekeeper [deleted 0 hist/trends, 0 items, 0 events, 0 sessions, 0 alarms, 0 audit items in 0.192291 sec, idle for 3 hour(s)]
  • volter
    • Dec 2011
    • 85
    This doesn't necessarily indicate a problem. When there is nothing to do, there is nothing to do.
    Also, 3.0 has some housekeeping settings in the frontend too. You might want to have a look at them.
