Disk READ/WRITE monitoring
  • jwilliam
    • Mar 2005
    I'm trying to add this item
    disk_read_blks15[sda4]
    but Zabbix tells me "Not supported by ZABBIX agent"
    I've also tried it with disk_read_blks15[/dev/sda4]
    None of the disk read/write monitors are working.
    Should it work with SCSI drives?
    using 1.1alpha7
    Thanks!
    ----EDIT----
    I am running zabbix_agentd on the client.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Yes, it should. Note that the agent does not support disk statistics under Linux v2.6.x currently. However it works under v2.4.x.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • jwilliam
      • Mar 2005
      hmm I'm using kernel 2.4.26
      Perhaps I'm missing something else.
      thanks
      ps. I get the same results on all of my Linux (Slackware) clients.
      • bardel
        • Apr 2005
        2.4.x doesn't support Disk READ/Write
        I have the same issue. Have you found a solution?
