Zabbix only in Firefox
  • Speedfight
    • May 2007
    • 67
    i want to report a bug
    when i try to login in with internet explorer. I can't login.
    Login is only possible in Firefox
    Kind regards
    Edit: sorry this only happens in 1.3.5
    don't know if this is solved in later version
    wasn't paying attentsion.
    sorry
  • vrtareg
    • May 2006
    • 293
    Hi
    The same problem for me.
    I can login without problems using Firefox.
    It is not possible to login using Internet Explorer. It all times redirects to login page.
    Areg
    • Firm
      • Dec 2009
      • 342
      Enable cookie files.
      • vrtareg
        • May 2006
        • 293
        Hi
        Cookies are enabled.
        I changed security to minimal one but still when I press login button I am going to login page back....
        Areg
        • russmeisner
          • Jan 2010
          No problem on 1.4.6
          • vrtareg
            • May 2006
            • 293
            I am using version 1.8
            • vrtareg
              • May 2006
              • 293
              Changed to version 1.8.2
              Still not able to login using IE version 7.
              Have no idea about login using IE8.
              Does anyone use IE8?
              Areg
              • hulting74
                • Nov 2008
                • 30
                Clear temporary internet files in Internet Explorer?
                • vrtareg
                  • May 2006
                  • 293
                  This does not work on several machines in the office.
                  I try to delete user profile and login with clean settings.
                  Same problem....
                  • vrtareg
                    • May 2006
                    • 293
                    Any ideas how to get it working in Internet Explorer?
                    Any configuration to be checked in Apache?
                    Areg
                    • vrtareg
                      • May 2006
                      • 293
                      Alexei
                      Do you have any ideas about this?
                      Can I somehow help to debug/investigate?
                      Thanks,
                      Areg
                      • Palmertree
                        • Sep 2005
                        • 746
                        We are using ie6 without any log in issues. Running Zabbix pre 1.8.3 Rev. 11784 and LDAP authentication.
                        • vrtareg
                          • May 2006
                          • 293
                          What about IE7 and IE8?
                          Did anyone try to login use IE7 and Zabbix internal authentication?
                          Areg
                          • Aly
                            ZABBIX developer
                            • May 2007
                            • 1126
                            So are we, here we have running different windows from 2000 to 7, and we can login by any IE (IE6, IE7, IE8 and even alfa IE9) they are all tested. So I'm pretty shore it something with your configuration on pc or server..
                            Zabbix | ex GUI developer
                            • vrtareg
                              • May 2006
                              • 293
                              #15
                              Aly
                              I cant login using IE7 from any of workstations in our office.
                              I upgraded GUI from version 1.8.0 to 1.8.1 and now I am using version 1.8.3 and I cant login using IE7, I can only login using Mozilla.
                              Could you help me what I can check on server?
                              I am running server on CentOS 5.3:
                              apache - 2.2.3
                              php - 5.1.6
                              mysql - 5.0.77
                              snmp - 5.3.2.2
                              I increased log level to maximum in apache but still no results.
                              Areg
