Zabbix only in Firefox
  • vrtareg
    • May 2006
    • 293
    #16
    Aly
    I also try to login from Windows 2000 server, with IE6 - no success.
    It seems there are some misconfiguration in my linux server.
    Areg
    • Aly
      ZABBIX developer
      • May 2007
      • 1126
      #17
      1. If your windows PC's are in ms domain, I would check domain policies.
      2. Try to access on any other webpage on same server where zabbix frontend is located from IE if you can then apache conf is ok.
      My guess is that there is something wrong with storing cookies by IE
      Zabbix | ex GUI developer
      • vrtareg
        • May 2006
        • 293
        #18
        Aly
        All other pages are displayed normally from same server.
        Also I can open and browse Zabbix pages as a guest.
        I will check our domain policies for IE settings.
        I can also try to login using IE 7 from workstation which is not included in domain.
        Thanks for information.
        Areg
        • vrtareg
          • May 2006
          • 293
          #19
          Aly
          There are no group policy settings for IE.
          All other sites cookies are working perfectly.
          I cant imagine what else I can check.
          Areg
          • Palmertree
            • Sep 2005
            • 746
            #20
            Check advance security settings in IE. Maybe try and make your Zabbix site a trusted host so the security in IE is lower.
            • vrtareg
              • May 2006
              • 293
              #21
              Hi
              I tryed to decrease IE security levels to minimum and add Zabbix site as trusted everywhere.
              No change. I can login using Firefox but not IE6 or IE7.
              Areg
              • vrtareg
                • May 2006
                • 293
                #22
                It seems frontend can't set any cookies even when i set security to the lowest level and allow cookies from any site.
                Cookies are normally accepted in Firefox.
                Areg
                • Aly
                  ZABBIX developer
                  • May 2007
                  • 1126
                  #23
                  As I sad before, there is something wrong with cookies in IE
                  • vrtareg
                    • May 2006
                    • 293
                    #24
                    Is there any possibility to track/debug this to understand ?
                    • vrtareg
                      • May 2006
                      • 293
                      #25
                      Hi
                      It seems I solve problem.
                      IE does not accept cookies from the hosts which contain _ (underscore) in hostname.
                      Server hostname contains _ in a middle. Changed it to - (dash).
                      Areg
