I was configuring zabbix 1.4. Everything was fine until I enabled web monitoring (just 1 scenario with 1 step).
If I enable it, the server dies few seconds latter (see the attached log).
If the scenario is enabled and I try to restart zabbix_server it dies few seconds latter. Then, if I disable the scenario and try to restart, it works well.
