Problems on linux install !
  • DmK
    • Apr 2005
    • 10
    hello,
    I am a newbe on Linux, i must install and try zabbix for my company.
    I work on linux mandrake 9.2.
    I have uncompressed files in files:/home/my_name/Documents/zabbix-1.0/...
    I have followed the manual as much as possible with my knowledge,
    in zabbix directory i have done ./configure --with-mysql --with-snmp which had worked well, i follow the message and do a simple "make"
    But after the make nothing goes outside of zabbix directory, then i copy myself the files in the directories of the manual to complete it.
    I launch suckerd and trapperd, and try to get zabbix by konqueror but host missing, apache is correctly running.
    Could you help me please, i have broke out the 15 minutes amx install time i believe
    Thanks.
    EDIT: I have found another manual more simple for me , everything is working on the server side , i'm still trying to connect to the client !
    By the way thanks for this excellent program!
  • rajeevtomar
    • Mar 2005
    • 50
    Please check the conf files, if they have the hostname in them.
    Rajeev
    • DmK
      • Apr 2005
      • 10
      Thanks, I resolved this problem by myself yesterday but i still have some troubles:
      1/ apache processes not detected when the apache server is running, i can reach it by konqueror
      2/ No mail coming to mailbox for alarms (did not have any alert yet), maybe a problem in the smtp helo ( i didn't really understand what it is)
      Thanks for reply
